Water Injection
Tomson
Water Injection
Post by Tomson » Fri Oct 01, 2004 10:00 am
Has anyone ever tried water injection (Aquamist or simular) as a way of increasing power.
Pros and/or cons ?
Seems a reasonably cheap way of keeping temperature low...
Tom
Julesm
Post by Julesm » Fri Oct 01, 2004 10:33 am
Not tried it yet but have been looking into it (I have my eye on a kit!). There are quite a few brands out there offering some very tempting kits at reasonable prices. A friend of mine is currently fitting one to his car, so I will wait and see what improvements it makes. His car isn't an Audi, but it will still be interesting to see what sort of gains the water injection will make.
JohnW
Post by JohnW » Fri Oct 01, 2004 10:59 pm
Tomson,
Guy has an aquamist kit fitted to his supercharged VR. Might be worth giving him a shout on the ccgb board to see what he has to say about it.
I think once it is set up it works quite well, but with a turbo'd RS4 I would have thought bigger intercoolers would be a better option...
Cheers,
John.
Too many toys, not enough time
bjacks
Post by bjacks » Sat Oct 02, 2004 10:34 am
JohnRS4 has a kit fitted by QST IIRC :D
He'll be your best bet.
Ben
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Oct 06, 2004 12:26 pm
this is a link that i have found on water injection
http://www.aquamist.co.uk/rescr/rescr.html
thinking of fitting to my S4
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Nige_RS4
Post by Nige_RS4 » Wed Oct 06, 2004 12:56 pm
Ask over on the audiworld forum - there are a few S4 owners over in the states with some experience of the aquamist system.
Andiroo
Post by Andiroo » Wed Oct 06, 2004 1:59 pm
Hi guys, discussed here http://www.rs246.com/index.php?name=PNp ... highlight=, but I only used it as direct port and not on the I/C's. It worked very well indeed :P
Andiroo.
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Oct 06, 2004 3:23 pm
Dialynx offer a water injection kit for audi's.
can been fitted same day. (couple of hours)
Anyone used Dialynx for work before?
MING BLUE AUDI S4
Car is on Lock down
john_banks
Post by john_banks » Sun Oct 17, 2004 9:50 am
With adequate intercooling, water injection usually works best post-intercooler as the benefits are realised in-cylinder from detonation suppression.
If the ECU has pulled timing because of detonation, it may be able to advance the ignition timing again and gain more power and torque.
It really gains power though when the base ignition maps are advanced to suit the smoother cylinder pressure profile, and also the fuel dumping is reduced as you can use the water rather than fuel for cooling. However, if you then depend on it, you need a water flow sensor (which Aquamist can provide) to say drop the boost if the water fails as otherwise you could lose an engine. I found that you gain rather more with ever increasing concentrations of methanol injected instead of water, although not everyone else has found this. An easier method for me was methanol in the fuel tank, but that is frought with other considerations but can work astonishingly well, with 40 BHP gain in power. In the end I just got an even bigger turbo to cut hassle.
Impreza, 2.5 turbo, 440 BHP, 400 lbft, 0-60 3.9 (wet), 0-100 8.7, 0-125 12.1
jeffw
Post by jeffw » Sun Oct 17, 2004 4:07 pm
Wow...John Banks from Scoobynet "Sluming" it on rs246.com.....whatever next. You after a fast car then John....;)
PhilT
RS246.com
Post by PhilT » Sun Oct 17, 2004 6:49 pm
Nice write up John. Had a quick look at Scoobynet..... Welcome to RS246 John, looks like you bring a wealth of knowledge.
Got to admit "0-60 3.9 (wet), 0-100 8.7, 0-125 12.1" is impresive, but is it appropriate for a sig?
john_banks
Post by john_banks » Sun Oct 17, 2004 10:30 pm
Hi Jeff :)
Hi PhilT :)
Rice boy considering under-rated refined Teutonic saloon for wife ;)
Julesm
Post by Julesm » Sun Oct 17, 2004 10:35 pm
:mrgreen: ......Stick with your other signature, it's much more impressive!! :wink:
Does that mean you are on the lookout for an S4 or A6 2.7T?
john_banks
Post by john_banks » Sun Oct 17, 2004 10:54 pm
Considering one, or (cough) a late 330d remapped, heard 410 lbft was possible, not as silly as it might seem especially as the wife will be doing some mileage, although RWD and Scottish weather don't always mix. Anyway, you don't want a newb polluting a technical thread with chit chat ;)
jeffw
Post by jeffw » Mon Oct 18, 2004 8:19 am
John, you chat away ......
