carbon clean
carbon clean
Hi all,
I think I may have found a suitable rs4. It has done c40k and wondered, if the carbon clean process has not been done, is it likely to need it?
Best regards
Best regards
- Tile Diver
Re: carbon clean
Probably, it certainly won't do it any harm anyway, they do carbon up relatively quickly these cars! Get it on the rollers and see what its producing, and assuming there are no other under lying issues it may give you an indication of what its like in there.
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
- Revolution
- Trader (Expired)
Re: carbon clean
pm sent with some help
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Re: carbon clean
Anything that might be useful to others regarding this?Revolution wrote:pm sent with some help
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
- Graeme4130
Re: carbon clean
I think that question's pretty much unanswerable without seeing or driving the car
I've seen 90k cars that still make plenty of power as well as 30k cars that need a drastic clean out due to never being used properly
Only real test is to get it RR'd
- PetrolDave
Re: carbon clean
An RR test is not very useful when you're after an absolute value, there are just too many variables.Graeme4130 wrote:Only real test is to get it RR'd
RR tests are great for comparing before and after having work done, but IMHO not useful to determine whether work is needed.
- Graeme4130
Re: carbon clean
Entirely agreePetrolDave wrote:An RR test is not very useful when you're after an absolute value, there are just too many variables.Graeme4130 wrote:Only real test is to get it RR'd
However, if you RR it somewhere that knows RS4's (such as MRC) then they'll be familiar with the various output parameters, and should be able to give a good indication of whether its clogged up or not
Re: carbon clean
Deffo going to get mine done when funds have recovered from buying it. It feels rapid compaired to my old R32 but even an additional 100hp would feel drastically different and that would be a circa 380hp at best.
Think I'll go for a carbon clean, exhaust and map all at the same time. Some pain in the wallet there!!!
Interested to follow your progress if you go for it.
Re: carbon clean
Thanks all for the great advice
Users browsing this forum: Majestic-12 [Bot] and 178 guests
