Driving an RS4 slowly and smoothly
iluvmercs
Re: Driving an RS4 slowly and smoothly
Post by iluvmercs » Tue Mar 19, 2013 4:22 am
Thank you all for the further replies with hints, tips and opinions.
It sounds rather obvious, the Sport button option - I never drive the car without Sport engaged and traction control switched off completely (to non blinky light stage :wink: ).
so, I'll give that a go first.
I'll also attempt the other suggestions where possible and let you all know how I get on - mind you I'll be without my car for a couple of days while she undergoes headlight replacement & front brake upgrade, along with a general check over after the all the snow :)
Many thanks again for everyone's input :beerchug:
Darren
Coaster
Post by Coaster » Tue Mar 19, 2013 9:52 am
sonny wrote:Wasn't SW0090 suppose to map out 'kangarooing'?
Is the car mapped?
I have SW0090 + Standard map and it still does it.
Madmonkee
Post by Madmonkee » Tue Mar 19, 2013 11:05 am
Mine got a whole lot better after replacing a £15 clutch switch :) well worth it.
Post by MikeFish » Tue Mar 19, 2013 12:49 pm
iluvmercs wrote: It sounds rather obvious, the Sport button option - I never drive the car without Sport engaged and traction control switched off completely (to non blinky light stage :wink: ).
Ah, that's probably it then! I used to drive all the time with Sport mode on. Like i mentioned earleir there is a slight difference with jerkiness. But when sitting in traffic you've nothing to gain with sport mode on other than the sound from the exhaust. Just disconnect the valves and you won;t need to be in Sport mode all the time and your exhaust will sound better as the valve wont only be open at certain revs. Win - Win!
adsgreen
Post by adsgreen » Tue Mar 19, 2013 12:55 pm
the other advantage is that when you do use sport mode after using non-sport it does give the impression things are a little bit "zippier"
Coaster
Post by Coaster » Tue Mar 19, 2013 1:30 pm
adsgreen wrote:the other advantage is that when you do use sport mode after using non-sport it does give the impression things are a little bit "zippier"
it's barely perceptible to me in my car! In the E46 M3 if you drove on a constant throttle and pressed sport mode you could immediately feel the throttle map change.
Post by MikeFish » Tue Mar 19, 2013 4:56 pm
I didn't think the difference was a lot. A bit jerkier was about all I could feel. The MRC remap makes it feel like a different car! The difference now between sport and non sport mode is massive, there's no doubt which mode yoh are in!
adsgreen
Post by adsgreen » Tue Mar 19, 2013 5:48 pm
Its a bit smarter than that (well, appears to be). It definately doesn't just swap maps - a couple of times I've had to come off the throttle for it to pick up the new map.
But saying that... I've had it almost shoot off and spear the car in front when I've pressed it.
It does seem to depend on where you are with the throttle pedal when you press it.
PetrolDave
Post by PetrolDave » Tue Mar 19, 2013 6:58 pm
Only the cold start kangarooing.
Andyy
Post by Andyy » Thu Mar 21, 2013 2:37 am
I always wondered this haha, scared the life out of me the first time it happened. Only happens to me if i don't warm the car up long enough before driving it
esp_mm-270
Post by esp_mm-270 » Thu Mar 21, 2013 12:24 pm
I'm a bit late on this one but mine is the same, very, very hard to drive smoothly slowly. Going for it I've never driven anything that's so easy to drive fast. I think is like getting a roided up race horse to walk, there's gonna be a lot of snorting and complaining going on coz the car/horse just wants to run!
Mark.
Users browsing this forum: Google Adsense [Bot] and 153 guests
