Re: Help please - gearbox issue - BAD BAD NEWS!!
sweegie
Re: Re: Help please - gearbox issue / replacement gearbox
Post by sweegie » Tue Feb 26, 2013 8:43 pm
Shoppinit wrote:Fixed:
sweegie wrote:To check the level you need to get under the car and undo the gearbox fill plug with the engine running. Unfortunately there's no dipstick as such and you just fill it until fluid starts to weep over the fill plug level at exactly 35°C between 30 °C and 40°C fluid temperature and after running through the gears. It's a messy job, but straight forward enough if you can get the car lifted.
Repartee, mon ami...
Recycling dinosaurs for fun
Drummerman
Post by Drummerman » Tue Feb 26, 2013 11:39 pm
I had Grizz do my gearbox last year, mine was around the same mileage when it started playing up. Nearly a year on and it is still sweet and has never missed a beat. I spoke to the guys at Chester Automatics (think that's what they are called) who rebuilt the box for Grizz and they seemed to know their stuff. I would definitely go to him to sort the box out and get any other annoying faults sorted while he has the engine out.
mik15
Post by mik15 » Wed Feb 27, 2013 7:22 am
if i had someone like Grizz here i wouldn't even consider going to someone else, think of it on a long run, even if it will cost you a bit more in the end i am pretty sure you'll be satisfied and have peace of mind afterwards! My engine and gearbox are out as we speak for a torque converter replacement, be prepared for additional costs as there will be a few seals, gaskets, EGT sensors, O2 sensors, oil cooler pipe, maybe engine/gearbox mounts and other bits that will need(MUST) be addressed if you wanna keep the car longer and besides a good chunk of money it will take time as many of the small parts are not in stock at the Audi dealerships and will have to be ordered from Germany, mine is been apart for almost 1 month now due to some silly turbo gaskets and cooling pipe o-rings which were nowhere to be found but Germany! I am also gambling as i have chosen not to refurbish the gearbox as it didn't slip, hopefully will not start afterwards due to the new converter :) !
2004 RS6 by ABT, madly in love with it, RNS-E, ST coilovers, new TC, 19x9x29 RS4 B7 wheels, non-resonated Milltek w/blk tips, TBC....SOLD - but never to be forgotten!
2004 RS6 ebony schwarz, SE exhaust, 19'' rims - SOLD
'09 RS6 C6 - the great white - now, this means business!
captrs6
Post by captrs6 » Wed Feb 27, 2013 9:28 am
Hi Folks - just an update..
The car started and drove for about 10 minutes 2ith no issues in relation to the gearbx? No limp mode and it went through the gears!!!
Ideas???
2003 C5 RS6 - Stage 1 Re-map, KW Coilover Kit.
The C5 is the S&M of car ownership - "Pleasure and pain".
posterboyj
Re: Re: Help please - gearbox issue - UPDATE!!
Post by posterboyj » Wed Feb 27, 2013 9:53 am
Diagnostic scan?
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
rossi46
Post by rossi46 » Wed Feb 27, 2013 11:06 am
Drummerman wrote:I had Grizz do my gearbox last year.....
Drummerman ; purely out of interest, do Unit 20 not actually carry out the rebuild themselves ? It's CA that physically undertakes the work ?
Post by chunky79 » Wed Feb 27, 2013 11:52 am
Grizz wouldn't strip and rebuild the box. He would remove and fit.
Post by chunky79 » Wed Feb 27, 2013 11:53 am
captrs6 wrote:Hi Folks - just an update..
Ideas???
Let it get up to temp then report back.
Welcome to C5 ownership, it screws with your head.
Mr V10
Post by Mr V10 » Wed Feb 27, 2013 11:54 am
Unit 20, just like MRC/AMD or any other specialist will send the gearbox to a specialist to be refurbished, or in the case of Audi, just slap a new one in. A gearbox specialist will be able to remove and refit though. Chester Auto Transmissions are very good, they also have a high tech machine for doing a proper gearbox flush when doing an oil change.
sweegie
Post by sweegie » Wed Feb 27, 2013 11:56 am
Ideas???
Dead fluid or a clogged filter, or both would be my optimistic guess. I ran 10 litres of fluid through my box, and had a detergent / seal conditioner in there for 1000 miles when i serviced my box. All was much happier by the end of the treatment.
rossi46
Post by rossi46 » Wed Feb 27, 2013 12:08 pm
@ chunky/amar ; ah ok .. surprised at that to be honest.
captrs6
Post by captrs6 » Wed Feb 27, 2013 12:15 pm
Thanks folks - first step is to get flush and replace fluids and filter....hopefully this will work :-)
Can anyone confirm suitable products for the flush and oil?
Mr V10
Post by Mr V10 » Wed Feb 27, 2013 12:21 pm
Get the filters/oil from Audi or TPS. Who is doing the flush, try Chester Auto. They have the machine to do it properly.
Post by Shoppinit » Wed Feb 27, 2013 12:23 pm
See the FAQ for the correct ATF.
Mr V10
Post by Mr V10 » Wed Feb 27, 2013 12:25 pm
Read this review on Chester Auto
http://forum.a8parts.co.uk/showpost.php ... stcount=14
This is interesting, too. (Bloke took his car to ZF to have it done).
http://www.bimmerboard.com/forums/posts/527361
Users browsing this forum: Majestic-12 [Bot] and 131 guests
