Re: Help please - gearbox issue - BAD BAD NEWS!!
Hi All,
PLEASE PLEASE HELP!!
I have had an issue with the gearbox yesterday. The car struggles and revs to get into 2nd gear.
After running it through the laptop, error code 17116 originally appeared. After clearing it and running it again, the error code 17114 appears confirming 2nd gear ratio.
What is the best way forward? The car is located in Glasgow. Based on the symptoms outlined, is the gearbox totally gone.
I have spoken with two garages who have informed me that they want circa £3-4k to remove and recondition the gearbox.
Any help wuld be greatly appreciated!!
Cpt
Cpt
2003 C5 RS6 - Stage 1 Re-map, KW Coilover Kit.
The C5 is the S&M of car ownership - "Pleasure and pain".
Re: Re: Help please - gearbox issue
Other than low ATF, it sounds like your tranny is nice 'n' toasted. Call Grizz, get it flatbed it to Wirral.
How much are we looking at bam-bam??
Grizz could probably answer that. £3-£4 is doable but not sure of the quality, Grizz's pricing might be more but the quality can be assured.
Cpt, is your car standard?
Are you looking at keeping it for a long time?
If it is mapped and you are looking to keep it for a few more years then I would go with a modified box, otherwise just ask grizz for an OEM.
Ben was on here a few months ago and he was also looking into an uprated box.
Hi Chunky - Car is bog standard 72k miles on it. I deally would look to keep car for few more years. Whats the main difference between them??
My gearbox expired at 72K Grizz did it for me, the difference is that the AMD option looks better as the box is warrantied for 3 years and the one Grizz fits is only warrantied for a year afaik unless he has changed the warranty period. Both options you will have to pay labour if the box goes again. If you get a gearbox from Audi you get 2 years parts and labour.
Re: Re: Help please - gearbox issue / replacement gearbox
Bilko - has anyone used Amd? Would be good to get feedback before i send it down..
.....I havn't read the post thoroughly/recently ( it was clear the way it was headed ! ), but I believe someone was asking for some specs on the rebuild ( around mid-Dec ? ). No information was forthcoming and I believe this is still the case ??
Grim. Have you checked the ATF? Did this happen immediately or have you noticed problems growing over time?
You have a few options here, as there is Mackie Transmissions in Glasgow who are very well respected ZF builders.... I'd be checking the ATF level first, before anything though, as this is easy to do and free / cheap....
I'm in glasgow too if you want a hand with anything
Recycling dinosaurs for fun
They were asking specs for the uprated box which will be a lot more expensive but probably cheaper than sending it to the USA and less hassle if something goes wrong. Give them a try, you can be the guinea pig
Mine has just been refurbed by QST. Picking her up tomorrow so will let you know how she drives once I've done some miles. Grizz is much closer to you and has a very good reputation!
RS6 C6 - Mugello blue saloon - H&S decatted 3" turbo-back exhaust - MRC filters & stage 2 map - 768PS/1091Nm
RS6 Plus - (was) Black - MTM Stage 2 - Down pipes (100 cell) and non-res Milltek - H&R ARBs - 535bhp/730Nm - sold
Users browsing this forum: srichards and 91 guests
