Brake Judder
2.5 I5 20v TFSI - 335 bhp
geek
Location: I was there for a while but now I am here, definitely here.
Re: Brake Judder
Post by geek » Fri Feb 15, 2013 4:11 pm
As far as I am aware the much discussed RS3 break squeal still doesn't have a permanent solution.
Mine is going in for a judder issue; Master Tech was ordering in replacement disks and pads, no mention of them being anything different to the current stock item.
Suzuka Grey RS3
P_G
Re: Brake Judder
Post by P_G » Fri Feb 15, 2013 5:14 pm
If the RS charter still exists (which I believe it does) it replaces discs and pads if such vibration issues are reported within the first 2 years of ownership but only 1 time. Then reliant on goodwill.
Having not really looked at the RS3 discs are they directionally vaned or pinned / slotted? If the latter they are like the Brembo RS4 discs that did eactly the same. Problem was cured with them with harder compound brake pads in EBC Yellowstuff or Ferrodo DS2500's but I do like the idea of some Loba discs this time....
Carrg
Re: Brake Judder
Post by Carrg » Fri Feb 15, 2013 8:20 pm
Nice, new disks.
Get the alu carriers coated/protected when new.
Ibis RS3 - Buckets - Bose - Black Ed - Privacy - Musical Brakes
VW California 180 DSG " Candy"
Dave_Hedgehog
Brake Judder
Post by Dave_Hedgehog » Wed Feb 20, 2013 11:45 am
P_G wrote:If the RS charter still exists (which I believe it does) it replaces discs and pads if such vibration issues are reported within the first 2 years of ownership but only 1 time. Then reliant on goodwill.
I suspect the loba upgrade will be the only way I can stop my grinding and judder
geek
Brake Judder
Post by geek » Wed Feb 20, 2013 9:24 pm
Fronts replaced in full and bedded in; let's see how these get on.
Suzuka Grey RS3
Daytona3
Re: Brake Judder
Post by Daytona3 » Wed Feb 20, 2013 10:13 pm
good luck geek :) btw when you say fronts replaced in full - would that mean disks, calipers and brake pads?
geek
Brake Judder
Post by geek » Wed Feb 20, 2013 10:16 pm
Daytona3 wrote:good luck geek :) btw when you say fronts replaced in full - would that mean disks, calipers and brake pads?
Cheers fella.
Disks and pads....no issues identified with calipers.
Suzuka Grey RS3
Daytona3
Re: Brake Judder
Post by Daytona3 » Wed Feb 20, 2013 10:23 pm
welcome :) did they venture a guess why there was that judder ?
geek
Brake Judder
Post by geek » Wed Feb 20, 2013 10:30 pm
Sorry chap, posted the associated update onto the other thread I had running on my cars drive line issue.
Essentially, 1mm+ run out on each disk that couldn't be pinned to a specific root cause. Paid close attention to bedding in with my Master Tech doing the first two runs at it personally.
Suzuka Grey RS3
geek
Brake Judder
Post by geek » Wed Feb 20, 2013 10:31 pm
Last sentence above was reference to bedding in the new set of disks and pads....for clarity.
Suzuka Grey RS3
Daytona3
Re: Brake Judder
Post by Daytona3 » Wed Feb 20, 2013 10:36 pm
cheers mate... thanks alot
P_G
Re: Brake Judder
Post by P_G » Wed Feb 20, 2013 10:40 pm
geek wrote:Sorry chap, posted the associated update onto the other thread I had running on my cars drive line issue.
The sort of run out sounds like highspots caused by pad deposition just from experience on the RS4 discs; I hope not....
geek
Brake Judder
Post by geek » Wed Feb 20, 2013 10:50 pm
Indeed.
Mine is the first that I am aware of though, not seen another 3 owner reporting like issues or have I missed something?
I wasn't overly careful with bedding in first time round....it's been done properly second time so let's see.
Suzuka Grey RS3
Carrg
Re: Brake Judder
Post by Carrg » Thu Feb 21, 2013 9:47 am
What bedding in procedure did you use?
Master Tech aren't allowed over 70mph are they?
Glad you got it sorted Mate.
Users browsing this forum: Google Adsense [Bot] and 17 guests
