TPMS Brain Pick
ArthurPE
Re: TPMS Brain Pick
Post by ArthurPE » Thu Feb 14, 2013 11:43 pm
not sure it answers all questions but helpful none the less
http://uberlame.com/a6_tsb/TPMS/TPMS%20 ... i%20Q7.pdf
http://wiki.ross-tech.com/wiki/index.ph ... ecognition
looks like battery life can be seen in Vagcom (assume VW and Audi use similar systems)
a whole forum dedicated to tpms systems
http://www.thetpmsforum.com/showthread. ... -Audi-TPMS
pDkALO
Re: TPMS Brain Pick
Post by pDkALO » Thu Feb 14, 2013 11:45 pm
Sensors are completely sealed and batteries can't be changed. Surprised a dealer is saying that at 6 years the batteries should be fine, as from what I've seen, most suppliers give 5-7 years as typical life
klauster
Re: TPMS Brain Pick
Post by klauster » Fri Feb 15, 2013 10:11 am
I had this fault for a few months, it was annoying. I went down the antenna route initially which did not cure the problem, a new set of sensors and valves did. They are not cheap when you are buying 4 but I did manage to get them on ebay for around £240
spikeyboy101
Re: TPMS Brain Pick
Post by spikeyboy101 » Sat Feb 16, 2013 2:51 am
Surprised you can't just change the batteries.
Just another way of making money. :audibash: :audibash: :audibash:
pDkALO
Re: TPMS Brain Pick
Post by pDkALO » Sat Feb 16, 2013 9:51 am
spikeyboy101 wrote:Surprised you can't just change the batteries.
Agreed, but to be fair, it's not unique to Audi, as virtually all manufacturers' sensors are sealed - in fact I wouldn't be surprised if they were all made by 3rd party companies to the same spec.
Brooner
Re: TPMS Brain Pick
Post by Brooner » Sat Feb 16, 2013 10:17 am
i had this a year ago i first replaced the antena chepest at about £70 and easy diy replacement still had errors then changeded all 4 sensors at £70 a corner still had errors then Audi had to replace the processor unit £400 so if your lucky its the antana but you can switch off the TPMS via Vagcom and just check the tyres the old fashioned way
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
PetrolDave
Re: TPMS Brain Pick
Post by PetrolDave » Sat Feb 16, 2013 11:26 am
DALO wrote:I wouldn't be surprised if they were all made by 3rd party companies to the same spec.
TPMS sensors are made by most of the major automotive suppliers like TRW, VDO, Schrader, etc.
http://www.tirepressuremonitoringsystem ... nsors.html
ArthurPE
Re: TPMS Brain Pick
Post by ArthurPE » Sat Feb 16, 2013 3:57 pm
correct, can't blame Audi
aren't ours Beru?
DuncanF
Re: TPMS Brain Pick
Post by DuncanF » Sat Feb 16, 2013 5:00 pm
All sorted, thanks to the wisdom in these forums. Plugged in the new antenna and then went through the "wheel change" routine and all is well.
Next up tyres and, shortly, front discs which are nearing their limit ...
Users browsing this forum: Google Adsense [Bot] and 98 guests
