Daytona Grey Goodness
Youngben
Re: The story so far...
Post by Youngben » Mon Feb 04, 2013 5:23 pm
TonyHayers wrote:What's that you're carbon skinning Ben? How's it going with porting/polishing that intake you got?
its the strip that sits on top of the rear bumper below the bootlid! havent started the porting yet but its all stripped ready i just need to get some tooling to do it! :beerchug:
Youngben
Post by Youngben » Mon Feb 04, 2013 5:43 pm
my day in pictures! my oil cooler pipes were not to bad just surface rust but still solid! but due to recent stories i am working along side a well known and respected company in getting ally aux rads made and also a replacement oilcooler setup which will replace the standard item all this will come together in time as they are very busy but i will update as and when.
Fitted the new ballast which isnt compatible with the active headlights or may need calibrating i need to look up more info on this! At the moment i have the headlight logo on my dash with a arrow over the top pointing left so guessing that is to do with the ballast and active headlights as its wasnt there before! but the light works as it should havent had a chance to try active just yet as it isnt dark enough.
Finnishing off the evening with flatting and laquring my bumper strip to refit and i have removed the front grill surround to get wrapped in the next few weeks! along with the new additions today i will be leaving it at that as dont want to go to far with the outside.
Anyway the bit we all like.....
Bumper off
Drivers aux rad got removed and all blocked off for minimal coolant loss
Damp on passenger side showing signs of a leak
Drivers v's passenger
Found a perfect T piece in my box of bits
Tided
Oil cooler pipes
Rubbed down and wax applied to slow down corrosion
Fitted cold air intake
Cleaned all threads on the bumper adjusters to loosen them and copper slipped everything to ensure it stays loose
Ballast comparison
Carbon fitted
And back in 1 piece minus the grill surround :)
rs4Mav
Post by rs4Mav » Mon Feb 04, 2013 5:53 pm
Nice job done, all looks well but don’t think your better half will be to chuffed with the mess on your driveway !
Youngben
Post by Youngben » Mon Feb 04, 2013 5:59 pm
Haha all is well its just a little coolant and some cleaning products it will all be gone with the first bit of rain
sonny
Post by sonny » Mon Feb 04, 2013 6:13 pm
Looking good Ben. That is a good view of the underside of the Induction kit.
Post by MikeFish » Mon Feb 04, 2013 6:32 pm
Good work mate. That's some of the best condition oil cooler pipes I've seen yet!
RIV
Post by RIV » Mon Feb 04, 2013 6:37 pm
You sure
Post by MikeFish » Mon Feb 04, 2013 6:39 pm
You're cheating, they are new pipes!
RIV
Post by RIV » Mon Feb 04, 2013 6:44 pm
You're cheating, they are new Pipes!
No no!! not new honest :oops:
Rick_RS4
Post by Rick_RS4 » Mon Feb 04, 2013 7:05 pm
looks smart, love the crbon, where did you get the materials, was it difficult?
RIV
Post by RIV » Mon Feb 04, 2013 7:26 pm
Youngben how did you fix the plastic ducting back on the car, doesn't that fix to the rad??
nij
Post by nij » Mon Feb 04, 2013 8:01 pm
Do you need to take bumper off to remove the alloy strip?
Liking the carbon bits, I've had the seat backs and a few interior bit done on mine too.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Youngben
Post by Youngben » Mon Feb 04, 2013 8:25 pm
Thankyou for the comments makes it worth while updating
Rick_RS4 wrote:looks smart, love the carbon, where did you get the materials, was it difficult?
Cheers i got them from here there and everywhere really! i use surf board gel coat and got black base coat from carbon mods and got the 3k carbon material from somewhere else but carbon mods also supply it! its kind of difficult as it isnt forgiving if you get it wrong or if you sand through to the material! it takes a lot lot lot of time depending on how good you want your finnish! i have sanded mine down the grades today and just put 6 coats of lacqure on it before i flat it again with 1500 grit and then finnish with a good polish! the materials are not cheep for a couple of parts to be honest to justify the cost you need to do a few bits! i am going to send my grill surround away as i dont think i can finnish it to the standard required
heres the part now after 6 clear coats
Silas wrote:Youngben how did you fix the plastic ducting back on the car, doesn't that fix to the rad??
Used some black cable ties just to fix it where it would screw into the aux rad and it sat naturally where it should be :thumbs:
Youngben
Post by Youngben » Mon Feb 04, 2013 8:28 pm
No mate just put pressure on the srip at the edge closest the boot compartment and pull towards you and it unclips out! dont do it in cold though as it will be more brittle and its not the easiest of tasks
Post by MikeFish » Mon Feb 04, 2013 8:36 pm
Ben
What did you do with the nearside aux rad? You put a new one in or bypassed it?
Users browsing this forum: Bing [Bot], Google [Bot] and 103 guests
