Water leak again
bilko1
Water leak again
Post by bilko1 » Mon Jan 28, 2013 2:58 pm
I have a bit of time off work so i decided to find out why my car keeps steaming up when not being used. I have already checked sunroof drains and bulkhead drains so knew it had to be something else. I removed all the trim and glove box and pulled the carpet up on the passenger side stuck the hose on in the bulkhead area and low and behold water starts coming in the passenger side floor from this Image the part number of the plastic tube is 4B0 260 113 and is called a funnel according to ETKA. I managed to break it trying to get it out (hidden bolt) but £3.92 from TPS won't break the bank :) The problem i have is TPS or myself can not find a part number for the rubber grommet in the floor, any ideas anyone? Shop!
I'm guessing this is the aircon drain tube / funnel but seems strange water is coming up through the grommet.
The grommet appears to be glued in with sealer.
gingertoss
Re: Water leak again
Post by gingertoss » Mon Jan 28, 2013 3:09 pm
I had the same problem on mine. It is the aircon drain, on mine the end had melted close due to the miltek heating up the heat shield, which the drain tube was touching. I just forced some welding rod through to unblock the end.
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
bilko1
Post by bilko1 » Mon Jan 28, 2013 3:17 pm
gingertoss wrote:I had the same problem on mine. It is the aircon drain, on mine the end had melted close due to the miltek heating up the heat shield, which the drain tube was touching. I just forced some welding rod through to unblock the end.
I hear what you are saying but the water is coming in from outside the car when i stick a hose in the bulkhead area not from the aircon unit. Good call on the Milltek causing a heat build up though.
gingertoss
Post by gingertoss » Mon Jan 28, 2013 3:21 pm
Might be road muck built up on top of the exhaust heat shield causing the water to flow up the aircon drain hole?
Post by Shoppinit » Mon Jan 28, 2013 6:11 pm
It *might* be 4B0 260 155. That's a 26mm grommet.
Post by Shoppinit » Mon Jan 28, 2013 6:15 pm
bilko1 wrote: I hear what you are saying but the water is coming in from outside the car when i stick a hose in the bulkhead area not from the aircon unit.
If the water is coming in through the pollen filter isn't it coming out of the aircon unit then?
grizz
Post by grizz » Mon Jan 28, 2013 7:47 pm
Have you tried to blow it out .... The end is formed to prevent water coming up the pipe ...
I would say it's blocked so not allowing water out .
Unit 20
0151 3366888
bilko1
Post by bilko1 » Mon Jan 28, 2013 7:57 pm
When I stick the hose in the scuttle area water poors out of the drain bungs on to the floor as it should but it comes in through the centre of that grommet. That grommet appears to be a lot lower than the scuttle area almost floor pan. The diameter of the funnel where it goes into the grommet is 15mm so 26mm outside diameter seems feasible, I'll get TPS to order it as if it's wrong they will send it back as they haven't got a clue which one it is.
bilko1
Post by bilko1 » Mon Jan 28, 2013 8:01 pm
grizz wrote:Have you tried to blow it out .... The end is formed to prevent water coming up the pipe ...
The water is coming in through the centre of that grommet with the funnel removed, I've poked and prodded it and blown it out. I'll have to get it on a ramp and investigate further.
grizz
Post by grizz » Sat Feb 02, 2013 4:34 pm
Did you get it sorted mate
Unit 20
0151 3366888
bilko1
Post by bilko1 » Sat Feb 02, 2013 10:12 pm
I think so, new drain tube fitted and grommet poked, prodded and blown out no, water coming in now. Any tips to dry out the carpet and sound proofing? I've sucked as much out as possible with a George carpet cleaner but it still quite damp.
Post by Shoppinit » Sun Feb 03, 2013 9:43 am
Condensing dehumidifier, if you've got one. If not then it's a question of leaving in a nice dry, warm place with the windows open.
And driving with the footwell heaters on full.
Did that turn out to be the right part number? In case anyone searches for it in the future?
bilko1
Post by bilko1 » Sun Feb 03, 2013 8:34 pm
I didn't order the grommet as TPS said they had ordered the correct one with the funnel, the original guy thought he had found it. When it turned up it was wrong but I didn't get the part number sorry. Would sticking the car in a body shops oven dry it out?
Post by Shoppinit » Sun Feb 03, 2013 8:39 pm
If you've got one... why not. :) Don't turn it up so much that the interior turns to goo. And roll the windows down.
Post by chunky79 » Tue Feb 05, 2013 8:07 am
Careful putting the car in an oven, the aircon gas will need to be removed first!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 243 guests
