Why all the Tar ??????
I thought it was normally in the heat of the summer you got this but my wife's S3 is covered in the stuff doesn't help that it's white . I have used the Auto Glym tar remover it takes ages is there anything better and why all the tar at this time of year???????
Re: Why all the Tar ??????
Maybe you drove on a freshly laid road?
- Tile Diver
Clay it man!!!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Valet pro tar and glue remover is excellent. Then as above, clay it.
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Freshly laid road round here you must be joking its pothole city. As for clay bar now that really is a boring job i managed the bonnet last year and nearly fell asleep
Ah now we're talking Valet pro will give it a go thanks might pass on the clay bar after though
Apparently autosmart tardis is one of the best if there is a lot to be removed
Tardis is probably the best stuff to use, but whatever you use don’t forget it is also going to strip any protection on the paintwork as well, so you need to re wax it etc again afterwards.
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
Just use a small amount of neat petrol.
Job done.
(then re-wax obviously)
Job done.
+1 took the words out of my mouthJust use a small amount of neat petrol.
Job done.
- 1st Gear
+1 this stuff is what you needRS3Simon wrote:Apparently autosmart tardis is one of the best if there is a lot to be removed
Someone mentioned claying above. I'd only recommend this after you've the guts of the crap off otherwise you risk scouring the paint with trapped tar in the clay.
Current: S4 Avant (B8)
Previous: RS4 Saloon (B7) | M3 (E46) | Honda Civic Type R (EP3)
Users browsing this forum: No registered users and 36 guests
