TerraClean RS4 test (FAIL FAIL FAIL)
Re: TerraClean RS4 test: LIVE(ish)
That one from october probably had a flexible end, just like the endoscopes they use in Ear Nose Throat to go up your nose and down to the vocal chords. Not cheap. Do most engine boroscopes do this?
Not all no, some however have the camera at 90º
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
- TonyHayers
- 5th Gear
Yeah, we tried with their borescope but it's just a bendy one (technical term). Tried for 40 mins to get it to bend up the cylinder but nope just got a very nice view of the shape of the top of the piston
06 Phantom Black Saloon:
^ GONE
^ GONE
- TonyHayers
- 5th Gear
Ok, first dyno results. They waited until we had 2 near identical runs.
Apologies for the dodgy photo, I don't have a scanner on me.
^ GONE
^ GONE
Wow, those figures do look low.
I think any clean will give good results on those.
BTW, I have a feeling that Costco (yes you read that right), do a bendy borescope.
Good effort for doing this and posting it.
- 'R'e'S'pect_4
Be good to see the results Tony.
you sure are getting through your 'to-do' list in your sig! LOL
- TonyHayers
- 5th Gear
Aye, got my x-pipe getting fitted Monday too'R'e'S'pect_4 wrote:Be good to see the results Tony.
^ GONE
^ GONE
Nice one Tony, thanks for sharing.
Did you do a vacuum check prior to dyno run?
- TonyHayers
- 5th Gear
Hrm, no, got a howto - or do I need VCDS for that? I won't do anything about it now though so as not to mess with comparison. But does sound like I'm pretty low to start with. Lad at RStuning said it wasn't the lowest he'd seen though - they had one do 330 the other week apparently.sonny wrote:Nice one Tony, thanks for sharing.
^ GONE
^ GONE
- TonyHayers
- 5th Gear
FAIL FAIL FAIL.
This is a disaster of a test. They decided they can't actually do the terraclean. Fuse for fuel pump disables ignition (immobiliser?) so can't get car to run without disconnecting fuel pump itself, which they are convinced will mean taking fuel tank off.
Sorry to everyone for wasting your time.
Gonna go and punch a wall or something after wasting half a day on this. Over and out.
^ GONE
^ GONE
thats a shame you would think these guys would look in to the technical issues before they said to you they could do it
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
- TonyHayers
- 5th Gear
Yeah :/ The owner said that sometimes it takes a bit of fiddling to find the right places to plug into the fuel lines but just now told me they had a TTRS in the other day that they couldn't do for the same reason. *Sigh*.Brooner wrote:thats a shame you would think these guys would look in to the technical issues before they said to you they could do it
The photos of the place on the website are a little deceiving to say the least.
^ GONE
^ GONE
How do they rig this system up then?
Sounds very bizarre to me.
Did you tell them you were doing independent before and after tests
- TonyHayers
- 5th Gear
The machine replaces the fuel supply while it runs, so the machine plugs into the fuel supply and the return so the car runs off the system until the cans of the product are gone. It's pressurised to match the pressure of the fuel pump and burns the modified terraclean fuel from the machine... blah blah... no hydrocarbons... blah blah... arophatics... blah blah... aromatics... blah blah... negatively charged particles... blah blah...murph7355 wrote:How do they rig this system up then?
^ GONE
^ GONE
Wouldn't be happy with them wasted your time would be giving the owner a fecking telling about promoting a product they don't fully know how to use on your car after fill you full of <beep> about the benifits of it when they can't even hook it up
Users browsing this forum: Google Adsense [Bot] and 232 guests
