front right wheel knocking sound
s4bandit
Post by s4bandit » Sun Jan 06, 2013 2:19 pm
hi guys
I have recently developed a knocking sound from the front right wheel, it only happens when the car is turning a tight left corner
and 'knocks' once per revolution of the wheel
it stops again as soon as the steering straightens up
also it doesnt do it straight away only after the car has been driven for a bit
and its loud enough to hear with the window up ( just )
the rest of the time the car appears to be driving as it should
anyone got any idea's pls ?
cheers
B7 RS4 saloon Black with black optics pack
previous
C5 RS6 avus silver Milltek with remap 493bhp
E46 M3 ( had to give it a go, hated every minute )
B6 S4 saloon Black
B5 S4 silver MRC tuned stage 1
sar
Re: front right wheel knocking sound
Post by sar » Sun Jan 06, 2013 2:23 pm
drive shaft?
b7rs4 phantom black, titan pack.
The_Coat
Post by The_Coat » Sun Jan 06, 2013 2:30 pm
I have this on mine always when I'm just turning off the drive.
Think it's standard for theses cars as remember seeing people post about this before...but I'm sure someone will be along to confirm.
RS4 Avant - Misano Red
sar
Post by sar » Sun Jan 06, 2013 2:37 pm
The_Coat wrote:I have this on mine always when I'm just turning off the drive.
yer all rs4s do this (full lock,slow speeds) but it sounds like s4bandit is describing something else.
s4bandit
Post by s4bandit » Sun Jan 06, 2013 3:13 pm
Don't think it sounds normal its too loud and I've not noticed it before it also doesn't do it when the car has just been started , ref the drive shaft is there anyway I could check to see if this may be the case ? What other symptoms would a drive shaft problem have ? It doesn't do it when the wheel is turning right and its only the right front that makes the sound not the left ? Ref the sound it could be described as a tap as well does that help ?
previous
B6 S4 saloon Black
s4bandit
Post by s4bandit » Sun Jan 06, 2013 6:31 pm
anyone else have any ideas pls ? cheers
previous
B6 S4 saloon Black
Gizmo68
Post by Gizmo68 » Sun Jan 06, 2013 6:43 pm
s4bandit wrote:Ref the sound it could be described as a tap as well does that help ?
Could be a worn CV joint?
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
PetrolDave
Post by PetrolDave » Sun Jan 06, 2013 7:56 pm
Every S4 I've owned, as well as my RS4, has clicked on full lock (left or right) especially when it's cold (when you also get tyre block "jumping"). So IMHO some clicking on full lock is normal, but if it happens when you're not on full lock then I'd say it's not normal.
Sc0rian
Post by Sc0rian » Sun Jan 06, 2013 9:22 pm
when i went to view my first rs4, the seller told me that the car made a knocking noise, described exactly the same in this thread. When I went for a test drive, I did hear it too, it only did it once and then went away. It didn't sound too healthy.
Not really helping, just throwing in my 2p :)
rs4Mav
Post by rs4Mav » Sun Jan 06, 2013 9:39 pm
Sounds more like the pads rattling in the calliper to me, dose it still do it if you press your brakes slightly?
s4bandit
Post by s4bandit » Sun Jan 06, 2013 9:59 pm
Cheers I'll try with the brake pedal pushed in and let you know :-)
previous
B6 S4 saloon Black
s4bandit
Post by s4bandit » Sun Jan 06, 2013 10:01 pm
Would it not do it all the time if it was that though rs4mav ? It doesn't do it when I first start the car only when it's been driven for a bit ? Cheers
previous
B6 S4 saloon Black
rs4Mav
Post by rs4Mav » Sun Jan 06, 2013 10:30 pm
Not in my experience no, sometimes it can take a little bit of driving before the pads slowly eases away from the disc if the disc is slightly out of true. Once you start to turn into a corner which side loads the wheel and hub/disc, this then can cause the disc to catch the pads on a high spot (resulting in pad rattling) until brake is depressed again.
s4bandit
Post by s4bandit » Mon Jan 07, 2013 12:20 pm
that was it rs4mav :-) tried this morning like you said it doesnt do it when you press the brake pedal
is it easy to fix ?
cheers :-)
previous
B6 S4 saloon Black
rs4Mav
Post by rs4Mav » Mon Jan 07, 2013 3:57 pm
In the past all i have ever needed to do is
Wheel off
Pads out.
Clean pads and stainless shim if one fitted and calliper.
Small amount of copper slip between back side of pad/ shim / and calliper piston.
Small amount of copper slip on top and bottom of pad in the area where it is contact with calliper.
Re-assemble.
Always worked for me on many different types of cars.
Hope you have the same success .
Users browsing this forum: Google [Bot], Zyox and 239 guests
