Possible Problem?
OskiRs4
Possible Problem?
Post by OskiRs4 » Thu Jan 03, 2013 11:00 pm
Hi :beerchug:
I tooke my Rs4 out today and let the oil warm up to 80 ish and put my foot down a bit from second, it felt almost a bit jolty and the power did not seem there almost like I lost the kick at 5000rpm
I noticed when I let off the pedal I always get a few thuds pops from the exhaust as I have high flow cats and non res, but it seems to be doing it a bit more,
And also when i let off the throttle it seems a bit jerky? this I noticed the most, not too dramactic but I am sure it did not do this before,
I t was fine after and at higher speeds I did not notice anything?
Now I am goingt back to Amd for a carbon clean etc as I only got 366 bhp after a stage 2 remap in November and they suggested for me to do this, I will mention the problem I had as I have nevr had it before, No lights on the dash etc,
Does anyone know what it may be? coil pack breaking down? I
adsgreen
Re: Possible Problem?
Post by adsgreen » Thu Jan 03, 2013 11:18 pm
366? My first guess would be to check the vacuum system.
One of the things you do when removing the intake manifold is replace te shitty cheap crap one way valve.
This can cause problems.
Checking the vac system is easy and doesn't take any removing of things (apart from the carbon engine cover at the front)
OskiRs4
Post by OskiRs4 » Fri Jan 04, 2013 1:12 am
adsgreen wrote:366? My first guess would be to check the vacuum system.
Hi there thanks for the reply,
is this something I could look at myself without causing any problems? It will gove me something to do tomorrow until I can get it booked in to Amd
I take it searching for splits?
The valve you mentioned I think thats the thing they told they would replace and reloacte when I had my de-coke does that sound the sae thing?
I was dissapointed with my 366 but I had a better tourqe increase+ I only had 340 before and a overfueling problem due to last owner putting in the high flow cats and not having the stage 2 to map out something I think it was a cat sensor or something, I thought I would of had more the had only done 55.000 when i got it, which is fairly low?
adsgreen
Post by adsgreen » Fri Jan 04, 2013 1:44 am
Vac leak easy.
S'cuse slightly pissed answer
You weed feck need a vac gauge and hand pump.
Remove front carbon engine cover
There is a double t vac line connector
This is the thing you test
Best check search archive for details as am far to inhibited ? To comment now.
RobM
Post by RobM » Fri Jan 04, 2013 2:59 am
adsgreen wrote:.....
Ads......Hang in there buddy.
LOL. Priceless! :beerchug:
'06 RS4(B7)Avant. Phantom black Black optics Privacy glass SS+ Buckets Roundy-roundy steering wheel K&N. Black is never gonna fade!
Also red '94 2.8E Coupe quattro.
1.9TDi Avant. Bl&&dy good workhorse.
Bessie the Tractor. International BD414, oh yes!
Ducati TTF2, Spondon Ducati F1 & random other bikes
adsgreen
Post by adsgreen » Fri Jan 04, 2013 8:26 am
Jeez - looked fine when I wrote it
The_Coat
Possible Problem?
Post by The_Coat » Fri Jan 04, 2013 9:29 am
adsgreen wrote:Jeez - looked fine when I wrote it
Was you drinking white sprit or something? Lol :)
RS4 Avant - Misano Red
adsgreen
Post by adsgreen » Fri Jan 04, 2013 10:03 am
Feels like it this morning
Madmonkee
Possible Problem?
Post by Madmonkee » Fri Jan 04, 2013 1:54 pm
Lol that was a very informative answer there Ads :) good effort considering!
spikeyboy101
Post by spikeyboy101 » Fri Jan 04, 2013 2:20 pm
does sound like a vac leak.
when AMD did my carbon clean they found a fault with the airbox power flap.
Replaced and moved the airbox Valve so its more accessible and also moved the valve under the manifold.
Users browsing this forum: Google Adsense [Bot] and 194 guests
