Dealer sticker, rear window
Everything you need to know about cleaning products and general car care
redrsr
Post by redrsr » Fri Dec 14, 2012 3:02 pm
Does anyone know of a fool proof way of removing the dealer Sticker from the rear window without damaging the heating wires??
R8 V10 Spyder
previous toys RS4 B7, 993RSR, 993 Turbo S, 944/68 S/C racercar, 996 C2, 993 C2, 944 S2, 944
gilford
Re: Dealer sticker, rear window
Post by gilford » Fri Dec 14, 2012 3:55 pm
Pull it off gently, use some of the mrs's nail polish remover to remove any residue.
There is a detailers product called "Tardis" which I've got, excellent at this, but not worth buying just for the one job.
Current - 2017 Nardo RS5 8)
Batfinnk
Post by Batfinnk » Fri Dec 14, 2012 5:44 pm
If it's really hard to get off try heating with a hairdryer first to soften the adhesive.
Previous car: 2005 S4 B7.
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Tue Dec 18, 2012 10:34 am
Batfinnk wrote:If it's really hard to get off try heating with a hairdryer first to soften the adhesive.
^^^THIS^^^
Heating it up helps soften the adhesive and should pull most of it away with the sticker....if there is a lot of glue left behind then nip to halfords and try AG glue remover or similar product....as mentioned the best out there is Tardis but is expensive and only comes in 5ltrs.....
adsgreen
Post by adsgreen » Tue Dec 18, 2012 11:03 am
Check out a product called "Goo gone"
It's incredible at removing residue and gunk and you can buy very small bottles for peanuts.
redrsr
Post by redrsr » Tue Dec 18, 2012 1:18 pm
Russ, think as the old gal requires your tender touch i'll leave it, I'll let you do it as part of the detail, be in touch
R8 V10 Spyder
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Tue Dec 18, 2012 4:38 pm
Not a problem mate....seems a sensible choice.... :thumbs:
Return to “Cleaning & Car Care”
