When I unplug the vacuum, both flaps open straight away....
Confused of London....
Answers is in the faqrpsxr wrote:as far as i am aware, thats a good thing. the default is open, so there shouldn't be an issue with the vaccuum then...
i have it as well that the valves don't always open when i want to, mainly when it's called the first few minutes after startup. i will have to investigate a little...
rgds robert
Any linkage can sieze if not maintained.wrekka wrote:Do the milltek ones also eventually seize up like this?
Assuming warm engine (see above) then the next step is to get vag com vcds hooked up as this has a testing function of the valves and will also report when the ecu is asking for the valves to be open. Both valve actuators are controlled by the same solenoid so this may have siezed/broken/failed.Gumball3000 wrote:I posted this some time ago and still have the problem... basically the S button doesnt open the valves. At first it gave me an excuse to buy a milltek, but doesnt operate the valves on the milltek either
Users browsing this forum: Bing [Bot] and 387 guests
