Poxy stupid steering rack bolts.
adsgreen
Post by adsgreen » Mon Nov 19, 2012 8:40 pm
Stupid bolt working it's way loose again...
One of the "magic three" bolts that are supposed to hold the steering rack in place. It's the one thats under the secondary ECU located hiding under the battery slidey cover thing under the bonnet.
They are tension style bolts so can't just keep doing it up otherwise will eventually break <sigh>
Tempted to thread lock the bloody thing in place (only blue not red).
FWIW though it sounds *exactly* like a fubar'd DRC - lots of low speed clonking/banging with the occasional creak over speed bumps.
lengster1
Re: Poxy stupid steering rack bolts.
Post by lengster1 » Mon Nov 19, 2012 8:49 pm
Yup mine had that a few years back,would only do it when lock to lock parking etc but boy what noise when it did!
F@tBoyF@t
Post by F@tBoyF@t » Mon Nov 19, 2012 9:11 pm
adsgreen wrote:Stupid bolt working it's way loose again...
Bit of a pain, but removing the bolt & cross-drilling the head & wire-locking to adjacent structure could be a permanent solution. Bit extreme....? You'd only have to do it the once
"57" RS4 Avus Avant
lengster1
Post by lengster1 » Mon Nov 19, 2012 9:20 pm
Ahh fellow aircraft boy by chance?
zed_hn
Post by zed_hn » Mon Nov 19, 2012 10:00 pm
Any one got any pics of where theses bolts are?, because I have the off creek and what not near the front right hand side
Madmonkee
Post by Madmonkee » Mon Nov 19, 2012 10:07 pm
Wire lock and gunk the badboy! ;)
adsgreen
Post by adsgreen » Mon Nov 19, 2012 10:08 pm
There's three.
Two near the steering column and one on the passenger side.
One of the steering column bots and the pax one are under the plastic panel that just pulls off under the bonnet.
Open the bonnet, take if the battery cover panel and then pull off the whole plastic plenum cover.
One is under the ecu and the other under the brake reservoir
The other is under the rack - need to access from the wheel arch.
Noyjatat
Post by Noyjatat » Mon Nov 19, 2012 10:12 pm
Araldite 241 is what we use for thread lock buddy on our cabs. Gives enough adhesion to hold the bolt/screws while still allowing them to be removed without shearing! And yes it's should be blue in colour.
adsgreen
Post by adsgreen » Mon Nov 19, 2012 10:13 pm
Bolts 2 and 6
adsgreen
Post by adsgreen » Mon Nov 19, 2012 10:16 pm
I prefer loctite blue myself ;)
Noyjatat
Post by Noyjatat » Mon Nov 19, 2012 10:43 pm
I think we still use that in Lynx vertical stabiliser panels. Works just as well :D
F@tBoyF@t
Post by F@tBoyF@t » Mon Nov 19, 2012 11:24 pm
lengster1 wrote:Ahh fellow aircraft boy by chance?
'fraid so.....
Currently back in the West Country, but I've worked mainly in Belgium, Holland, Germany & France in Design & Manufacture. 42 years experience in total with 27 years as a money-grabbing subby. (Catia jockey)
Never a dull moment, & I've loved every minute of it. Met & made lots of real friends along the way.
A great career choice for a young engineer.
Only (slight) regret is not having followed my first love - architecture, but we've built a couple of houses so that satisfied that urge, up to a point.
What about you?
Ian
"57" RS4 Avus Avant
rs4lee
Post by rs4lee » Mon Nov 19, 2012 11:28 pm
Yep had to tighten mine last month ... Every time I reversed off the drive or did a lock to lock manoeuvre I'd get that clunk ! As much as a pain they are to get to , it beats having to replace the rack :-o
joesnow
Post by joesnow » Mon Nov 19, 2012 11:35 pm
What's the noise you are all referring to??
I noticed today when on full lock to the right I was getting a really bad clunking sound. Could feel it throught the steering wheel quite badly. Is this the same thing you are talking about???
Current: 2010 A6 2.0 TDi
Gone: 2006 B7 RS4 Avant
lengster1
Post by lengster1 » Tue Nov 20, 2012 12:52 pm
Crikey,similar but im structures and modifications man and designer when it doesnt work :bigblink:
22 years at it and the last 12 or so as a subby.Built the hush hush aircraft that had a hand in finding Bin Laden and then arour plated the cockpit on the royal flight aircraft etc etc for whoever pays the best lol
Share your property design interest too,im in the middle of pretty much a new build (had to leave a few exterior walls as new build wasnt allowed with planners) its the biggest project by far ive done,way above what ive done with rip out and rent jobs but im pleased with it so far.
Users browsing this forum: Majestic-12 [Bot] and 1004 guests
