New Brand Products
- Reflect Russ
- Trader (Expired)
Re: New Brand Products
its a spray mate
Russ, I will have a litre of the snow foam and some of the glass cleaner please. Let me know total cost and I will send you the monies.
Dunc
Dunc
Payment sent.
- Reflect Russ
- Trader (Expired)
Thanks mate....will be posted UK Mail tomorrow....
Your Transaction ID: 08X5822208945253J
Received cheers Russ
Got mine too.
Russ, how much discount do RS246 members get on a full winter correction/protection detail?
- Reflect Russ
- Trader (Expired)
How much do you want....
Keep it sensible....
an interior and exterior winter prep would be £195 for an RS4-6 whether Avant or not....
Obviously travel isnt included in that unless you are within a 50 mile radius....
By the way has yours got natural hide finish...Aniline leather which is unprotected...if so its a nightmare to clean without moving the dye around....
- Reflect Russ
- Trader (Expired)
good to hear you guys got your products and sharpish at that....let me know how you get on with them....
- Reflect Russ
- Trader (Expired)
Androidmarrs Transaction ID: 67002774L69216009
Thanks for the nudge mate...
Russ, what do you recommend on dwell time when using it as snow foam? I've left it for 10 minutes yesterday and it was OK but wondered if longer is better? Also what pH is it as I am having Ventureshileed instaled at the mo and want to ensure the foam does not affect or lift the 3M film.
- Reflect Russ
- Trader (Expired)
Its pH neutral mate and 10 minutes is a decent enough amount of time TBH....I remove it after 5 or so minutes so 10 mate is ample...how did you get on with it....
I'd want a correction detail, I have an alacantara interior. Only really need the exterior doing. It will be doing 2-3k miles a year from Dec onwards so I'm looking to get it done then when it isn't in daily use.Reflect Russ wrote:How much do you want....![]()
I tried the snow foam yesterday, left it 10 mins but had pretty dried up thanks to the wind. Didn't foam any where near as much as I thought it would be cleaned great. I tried a stronger mix just for fun after and it got a lot thicker, about 60ml in the bottle.Reflect Russ wrote:Its pH neutral mate and 10 minutes is a decent enough amount of time TBH....I remove it after 5 or so minutes so 10 mate is ample...how did you get on with it....
Glass cleaner was great. Might get some of your sealent, I'm using Blackfire All finish at the moment.
R1NE FOAM!!
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Users browsing this forum: Bing [Bot] and 72 guests
