New to the board, but does anyone know if the turbo back exhaust setup from Supersprint fits on an S4? I know OEM RS4 down pipes need to be modified to fit an S4 exhaust but was wondering if you got the full deal, if you could avoid this. Also, isn't the RS4 SS 80MM vs. the S4 70MM.
Supersprint RS4 Turbo back exhaust fit on an S4
Ask Supersprint/Dealer for an adaptor when you order it.....also it maybe too long if you have a Saloon. Believe the Avant exhaust is two inches longer. Any decent exhaust shop should be able to fit it.
When i order those sportscats will those fit the on the original place??KayGee wrote:Ask Supersprint/Dealer for an adaptor when you order it.....also it maybe too long if you have a Saloon. Believe the Avant exhaust is two inches longer. Any decent exhaust shop should be able to fit it.
Because i'm not sure it will fit the S4 saloon.
I hope i'm getting it right so when i buy rs4 turbo's and place them right on the manifold (if it fit's the original s4 manifold i hope so
Then they would fit without any problems but when placed on the original S4 turbo's??
Is the whole so much smaller?? Or is there another big difference or am I see'in it clompletly wrong??
Grtz
Love the pssst ------ punch.
Users browsing this forum: Majestic-12 [Bot] and 81 guests
