Also what oil temps are you running as mine normally sits around the 100+ degree mark (100-104) and only occasionally on long runs with minimal turbo use will see late nineties. Is this commmon too? Having come from an RS4 that would sit aat low ninety's on oil temp and only saw 100+ when ragging it I just wondered if this ans the gear box thing was normal?
Miss coming home lights as well, can this be programmed in with VCDS along with when car is unlocked?
Ta.
