Plus spec?
Fathand
Plus spec?
Post by Fathand » Mon Oct 29, 2012 9:24 pm
Guys I've picked up so much info on here since taking ownership of my first 6 last year but one thing still beats me, what are the basic differences between a c5 & a c5 plus?
amanda1
Re: Plus spec?
Post by amanda1 » Mon Oct 29, 2012 9:45 pm
50 bhp unless you find a slightly more modified c5 that will eat a standard plus for breakfast ;)
950 nm torque!
Fathand
Re: Plus spec?
Post by Fathand » Mon Oct 29, 2012 9:56 pm
Appreciate that Amanda but are there any visual differences? Without a dyno reading I have no idea of real bhp figure....
amanda1
Re: Plus spec?
Post by amanda1 » Mon Oct 29, 2012 10:13 pm
Fathand wrote:Appreciate that Amanda but are there any visual differences? Without a dyno reading I have no idea of real bhp figure....
Titan wheels and exhaust tips optics iirc oh and a plaque on the inside giving the number but as always everything was an option and could be changed apart from the plaque ?
950 nm torque!
Mr Footlong
Re: Plus spec?
Post by Mr Footlong » Mon Oct 29, 2012 10:16 pm
It isn't 50bhp difference between a stock C5 and a + C5 that I am aware of. + models always come with the black optic pack from factory I believe. You should find an additional cooling rad behind each intercooler (unless removed for some reason). + models are ONLY estate models. If you could try a + and a normal side by side, you should find that the + has a quicker steering rack fitted too, whether this results in a tighter turning circle or just less overall turns from lock to lock, I don't know.
There is the plaque around the gear selector that is supposed to match the last 3 digits of the VIN too, if someone was sad enough they could fake it I guess but I really don't see why. Not sure if things like solar roof, blinds etc are standard kit but I doubt it. Some of the proper anoraks will be along shortly no doubt :)
Current:
Gone:
amanda1
Re: Plus spec?
Post by amanda1 » Mon Oct 29, 2012 10:24 pm
Mr Footlong wrote:It isn't 50bhp difference between a stock C5 and a + C5 that I am aware of. + models always come with the black optic pack from factory I believe. You should find an additional cooling rad behind each intercooler (unless removed for some reason). + models are ONLY estate models. If you could try a + and a normal side by side, you should find that the + has a quicker steering rack fitted too, whether this results in a tighter turning circle or just less overall turns from lock to lock, I don't know.
Actually I am sorry standard rs6's have 450!bhp and pluses have 480 ! But as mine isn't standard I get confused being blonde ;)
950 nm torque!
Re: Plus spec?
Post by HYFR » Mon Oct 29, 2012 11:05 pm
Use the search tool
And buy a plus, the classiest RS 6
Fathand
Re: Plus spec?
Post by Fathand » Mon Oct 29, 2012 11:19 pm
As always top quality info from everyone so thanks for that. Mine has the full blind kit, black optics, drilled disks etc etc but sadly (for this purpose only) it's a beautiful Black saloon so I guess if the + only came as Avant mines a boring(!) 450 bhp 'standard' RS6. Anyone with any history back ground on a 2003 carrying the Reg. LY53 TTF with a Northampton address from Nov 2006 till Nov 2011?
amanda1
Re: Plus spec?
Post by amanda1 » Mon Oct 29, 2012 11:57 pm
Piccie???
950 nm torque!
Nobby
Re: Plus spec?
Post by Nobby » Tue Oct 30, 2012 9:00 am
Edit: Ignore me, too slow.
Daytona RS6 Avant
Daveperc
Re: Plus spec?
Post by Daveperc » Tue Oct 30, 2012 10:05 am
Assuming you have the service book, then just stick all the option codes into the "Option Code finder" spreadsheet (think it's in Footers repository) and you can find out exactly what you have got! (Or at least what it left the factory with!)
Dave
Mr Footlong
Re: Plus spec?
Post by Mr Footlong » Tue Oct 30, 2012 10:29 am
/Edit stupid flaming phone.....
Current:
Gone:
Mr Footlong
Re: Plus spec?
Post by Mr Footlong » Tue Oct 30, 2012 10:51 am
Current:
Gone:
Mr V10
Re: Plus spec?
Post by Mr V10 » Tue Oct 30, 2012 1:07 pm
This thread will tell you EVERYTHING you could possibly want to know about the RS6 plus, read the posts by Hartage.
http://forum.rs246.com/viewtopic.php?f= ... 5&start=15
Digger
Re: Plus spec?
Post by Digger » Tue Oct 30, 2012 2:52 pm
473bhp
Optics - black roof rails, front grill & boot trim, exhaust tips
plaque xxx of 999
Exhaust is modified & subtly louder (hardly noticeable!!)
slight drop in drc suspension height I am led to believe, havent been able to confirm as yet on mine!
Cross-drilled discs
Darker gunmetal / anthracite rims
Extra cooling rads in engine bay.
RNSE screen standard
Yea I own one, need to to get some fresh rubber on it (see separate thread) :bigwave:
. . .& no doubt I have missed something out from the above list!? :nodder:
Users browsing this forum: Google Adsense [Bot] and 83 guests
