Battery drain ?
nihc
Re: Battery drain ?
Post by nihc » Mon Oct 29, 2012 7:16 pm
Hi,
Does your car have the Bose sound system? There's a "fairly" common problem where the Bose amp doesn't power off when you switch off the ignition.
It drains about an amp - which will flatten the battery in a couple of days.
It happened to my wife's Audi TT. I had to wire a relay in series with the Bose power line to cut the power to it when the ignition was switched off.
Problem solved.
See if you can place an Amp meter on the battery power line and, with the ignition switched off, pull each fuse in turn to see what's drawing power.
The Bose Amp will normally power-off after a couple of minutes - I bet yours isn't.
Regards, Chris.
linkman72
Re: Battery drain ?
Post by linkman72 » Mon Oct 29, 2012 7:43 pm
Cheers Chris that may well be it, the car has got feckin everything from the options list so I am trickle charging the battery again in situ and I will check the fuses in turn.
I hate electrical gremlins but if thats it I owe you a pint matey
linkman72
Re: Battery drain ?
Post by linkman72 » Fri Nov 16, 2012 8:36 am
Well a new battery and a new starter motor required :cry: :shock:
£650 :shock: :shock:
spose me zorst will have to wait til next month
seems to have cured the battery drain though
linkman72
Re: Battery drain ?
Post by linkman72 » Wed Dec 05, 2012 9:21 am
Well it appears there was definately battery drain from the starter motor, can leave the car for a week now and it starts on the button. :bowdown: :thumb:
