Stone chip question?
Everything you need to know about cleaning products and general car care
OskiRs4
Post by OskiRs4 » Sat Oct 13, 2012 6:21 pm
Hi :)
Hi if a stonechip has gone all the way through to the bare metal, what is the best way to get it repaired the chip is about 2mm by 2mm very small and cant be noticed very well. but Im worried about the metal is not protected now, but does not warrent a pannel spray,
The car is a sprint blue B7 RS4, thanks
andre3k
Re: Stone chip question?
Post by andre3k » Sat Oct 13, 2012 6:56 pm
They don't make the little touch-up kits for Sprint for some reason, so buy this:
http://zakparts.com/shop/article_LLS%25 ... -LZ5F.html
Spray onto somat to collect the paint then touch in with a fine-tipped paint brush. Finally, lacquer over & wax to finish.
Reflect Russ
Trader (Expired)
Post by Reflect Russ » Sat Oct 13, 2012 7:33 pm
i may be able to help you out as i am in touch with a massive manufacturer of ceramic sealant and they are ready to unleash a touch up kit with each individual manufacturer colour...the kit also includes a small amount of ceramic to protect what you need to....i will keep you updated....
Batfinnk
Post by Batfinnk » Sun Oct 28, 2012 9:16 pm
Good tip for you all. The best place to get a decent brush for doing touch ups is either a model Shop like model zone or an artists supplies Shop. Normally they have very fine tips but nice thick handles so you can keep a steady hand when using them :bigblink:
Previous car: 2005 S4 B7.
gilford
Post by gilford » Mon Oct 29, 2012 4:13 pm
Plain old wooden toothpick is the best I found on a few of my older cars, brushes hold to much paint in my experience.
Current - 2017 Nardo RS5 8)
brn7y
Post by brn7y » Mon Oct 29, 2012 4:29 pm
I use a power washer nozzle cleaner, dip in paint, hold in chip and let paint run down into chip. Let dry then, buff flat with a bit of polish.
Post by chunky79 » Mon Oct 29, 2012 7:28 pm
gilford wrote:Plain old wooden toothpick is the best I found on a few of my older cars, brushes hold to much paint in my experience.
+1. Got this trick from Amar, he did a write up after doing his S8.
Return to “Cleaning & Car Care”
