Boot lid
Boot lid
Has anyone else had issue with the boot lid not going up high enough when you open it? It stops sort of 2/3rds from fully open. If I reset it with the button it sorts itself out. Until the next time...
Thing is, my wife's Q5 did exactly the same.
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Re: Boot lid
Isn't there still a lever in the hinge which stops the tailgate at 2/3rds height unless you push it hard to go right up? Or is that the reset button you mean? I recall seeing it on/in the right hand boot hinge on my Avant when cleaning the shuts
Re: Boot lid
I was told on the Q5 to press and hold the boot shut button, and it reset the open/close. I've not pushed it up any further, will have a look for a lever, but it doesn't seem right as conversely it really slams shut when you press the button to close. As if it's out of sync....?
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Re: Boot lid
My S4 is old school compared to a Q5 with power tailgate auto opening. From memory there's a notch in the right hand boot hinge which you can stick a screwdriver in to change between full height and partial height
- luffenham1
Re: Boot lid
Hi mate
Mine also does that. Started a few months back and not every time. Now it's lot luck whether the boot will open at all when I pull the leaver. I can hear the mechanism working but some times it does not release.
When it does open it opens 2/3rds of the way the as you say slams shut. Have heard that a new boot opening system cost £800
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
A6 C6 2.0 tdi Le Mans
RS6 C6 Avant, Monza Silver, Titanium Wheels, ITG Filters
RRS TDV8 ( Silly moment )
B7 RS4 Avant Daytona, R8 oil Cap
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Boot lid
Yup same symptoms as me. I'll be taking it in then!
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Re: Boot lid
Ian_C wrote:My S4 is old school compared to a Q5 with power tailgate auto opening. From memory there's a notch in the right hand boot hinge which you can stick a screwdriver in to change between full height and partial height
Thanks for that, I'll have a look and have a chat with the dealer
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Whitevanman
Re: Boot lid
Had this a couple of times with mine!
Replaced the boot lid struts both times and works fine till they are worn out!
50 mile road test to check them didn't make me very pleased!!
car hasnt been to a stealer since!
