First, if you look at the last picture of the fascia, you'll see the "prongs" on there that clip in to the cage in the car. These were just in the way and needed to come off.
Dremeled those beauties off and trimmed a lot of excess plastic off, which seems to be hard to trim small very detailed parts with a dremel, it just wants to melt everything!
I then reused the bits that I chopped off, trimmed them down and used them to hold the nexus in place. Plastic welding is fun!
I have tidied it up, and it needs some last bits of sanding and minor filling to touch up now. Tidied up the plastic welds too, now they're strong enough.
Just want to get some single sided black/grey foam, you know that comes on a roll? No idea where I would get that out here! That will tidy the edges as well as keep the tablet nice and tight in there and stop rubbing/ damage.
I've now taken apart a couple of magnetic cupboard door latches which I'm going to fit the magnet in to the top of the fascia to use to keep it tightly in place.
On we trott!
