Mod decision
5.0 V10 50v biturbo - 571 bhp
luffenham1
Re: Mod decision
Post by luffenham1 » Wed Aug 22, 2012 2:30 pm
Mind made up on the grill especially after the photos. Just going to drop the number plate. Thanks for the offer on the BBS CKs but i think i am going to stick with the CH-Rs if i can get them to fit plus that they look alright once on the car.
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
A6 C6 2.0 tdi Le Mans
RS6 C6 Avant, Monza Silver, Titanium Wheels, ITG Filters
RRS TDV8 ( Silly moment )
B7 RS4 Avant Daytona, R8 oil Cap
B7 S4 Avant, Black
C6NVS
Re: Mod decision
Post by C6NVS » Wed Aug 22, 2012 2:37 pm
Cool, be sure to update with some picks when you're done
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
ollys
Re: Mod decision
Post by ollys » Sun Aug 26, 2012 7:23 pm
Streem wrote:The gearbox map by MRC makes a HUGE difference when accelerating at full bore, not to be under estimated.
So, do you have this mod then and if so what other mods with it? My understanding was that this mod does two things - it makes the gear changes only very slightly faster than oem, and raises the rev limit to 7000 in all gears. This latter feature only comes into its own if the car is mapped AND has either secondary cat bypass pipes and/or catless down pipes, meaning the car carries on making power at the increased rev limit. Otherwise with just a catback, filters and remap the gearbox map makes little difference.
andy
Re: Mod decision
Post by andy » Sun Aug 26, 2012 8:37 pm
Now you mention it, what are the pros/cons of a secondary cat bypass? I was thinking that if I did get mine remapped I might as well go the whole hog and make the visit worthwhile but not sure if this introduces any issues?
C6 RS6 Avant in Mugello Blue - sold :(
BMW M2 LCi
catfood12
Re: Mod decision
Post by catfood12 » Sun Aug 26, 2012 10:22 pm
Ollys - Correctamundo fella. MRC Doug talked hinself out of a gearbox remap sale on my recent visit, explaining exactly what you said above. Lower revs power is limited to sensible levels to save the transmission anyway, onwards from stage 2 and MRC800 just maintain power above standard peak, around 6700 RPM, to over 7000. Exhaust, then turbos, become the limiting factor.
See my next post in reply to Andy's next question...
catfood12
Re: Mod decision
Post by catfood12 » Sun Aug 26, 2012 10:28 pm
andy wrote:Now you mention it, what are the pros/cons of a secondary cat bypass? I was thinking that if I did get mine remapped I might as well go the whole hog and make the visit worthwhile but not sure if this introduces any issues?
Stage 2 remap power peaks around 6700 RPM, same as stock. To push this up needs exhaust and optionally secondary cat bypass. MRCs recommended solution was Supersprint secondary cat bypass pipes and Milltek, then custom engine map and gearbox map to make most of area around 7000 RPM.
After stage 2 however you do need better brakes than stock steels if you're pushing on, say on country roads. Mine are now all properly blued and crazed on the surface. That's my next upgrade. We're trying to haul 2 tons of steel down from three figure speeds. Smelt like a cluth on a pensioners Daewoo Matiz. :piss:
andy
Re: Mod decision
Post by andy » Sun Aug 26, 2012 11:02 pm
Cheers for that explanation Cat, much appreciated :beerchug: I've already got the Milltek fitted so part way there, ok only a small part :D Would seem that just the stage 2 is the best bang for our buck then and anything more is another big step up cost. Still, always good to have further options open if you get bored again :biggrin3:
BMW M2 LCi
catfood12
Re: Mod decision
Post by catfood12 » Sun Aug 26, 2012 11:10 pm
andy wrote:Cheers for that explanation Cat, much appreciated :beerchug: I've already got the Milltek fitted so part way there, ok only a small part :D Would seem that just the stage 2 is the best bang for our buck then and anything more is another big step up cost. Still, always good to have further options open if you get bored again :biggrin3:
I will doubtless get the Supersprint pipes and a Milltek. Priority now is the brakes, after coming a bit too close to the trees on the A350 one (fast) night in the week. :oops:
andy
Re: Mod decision
Post by andy » Sun Aug 26, 2012 11:19 pm
Nothing like a close encounter with a tree to make you realise the value of good brakes!! Often overlooked but this is a big heavy brute that takes some stopping once getting a wiggle on.
BMW M2 LCi
scottie1979
Re: Mod decision
Post by scottie1979 » Tue Aug 28, 2012 11:53 am
Just for my own interest - if you were to take your RS6 to MRC for the 700ish hp transformation what should you be legally be declaring to have modified on your insurance? Obviously power increase, but what else ?
bobjebb
Re: Mod decision
Post by bobjebb » Tue Aug 28, 2012 4:12 pm
scottie1979 wrote:Just for my own interest - if you were to take your RS6 to MRC for the 700ish hp transformation what should you be legally be declaring to have modified on your insurance? Obviously power increase, but what else ?
Nothing else I don't think just the amended output figure... Not sure how many declare the changes? Likewise with Audi in terms of warranty...
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
doodlebug
Mod decision
Post by doodlebug » Tue Aug 28, 2012 4:24 pm
Audi will work it out for themselves. If you goose your drivetrain reasonable to expect a large bill and no warranty support!
perthwaRS6
Re: Mod decision
Post by perthwaRS6 » Tue Aug 28, 2012 7:04 pm
quote]
Hi catfood, :bigwave:
previous owner of my C6 RS6 sedan had a supersprint exhaust replacing the OEM exhaust- found it too 'boomy' inside with the windows up with the APR map for his liking and went back to standard OEM exhaust FWIW.
Having said that, i most likely will re-invent the wheel and will try an electronic secondary bypass cutout just ahead of the secondary cats. :lol:
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
catfood12
Re: Mod decision
Post by catfood12 » Tue Aug 28, 2012 10:31 pm
Honesty is always the best policy. My insurance company added £35 surcharge (yep, thirty-five pounds), for 'engine ecu chip' modification. No other details requested or provided. Had the same on a previous 535D, same surcharge, not a big deal these days I think as so many do it, and it probably doesn't make a tangible difference to their risk.
andy
Re: Mod decision
Post by andy » Tue Aug 28, 2012 10:33 pm
Who are you with out of interest Catfood?
BMW M2 LCi
Users browsing this forum: Google Adsense [Bot] and 81 guests
