New C6 RS6 Owner :)
5.0 V10 50v biturbo - 571 bhp
C6NVS
Re: New C6 RS6 Owner :)
Post by C6NVS » Sun Aug 19, 2012 9:33 pm
Welcome salamanzer
Not sure about the C6, but did have some trouble fitting non OEM batteries in the C5 due to slightly different sizing, so that would be a consideration for C6 replacement.
On another note, you can also enable the battery level monitor in the MMI. I'll try to find the link.
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
C6NVS
Post by C6NVS » Sun Aug 19, 2012 9:40 pm
here: here: http://forum.rs246.com/viewtopic.php?f=47&t=97385
Need a Vagcom, which I can help out with if you are in London, but sure you"ll find someone near you.
salamanzer
Post by salamanzer » Sun Aug 19, 2012 9:57 pm
I'm in the south west.... i may be able to find someone local.... or absolute worst case a stealer....
This looks to be the battery, if i was to swap it would i have any issues with dropping the power in the car whilst the batteries are swapped, the replacement battery cost is getting picked up by the supplying car dealership
http://www.thebatteryshop.co.uk/610-402 ... 2836-p.asp
Jason
2008 Audi RS6 C6 - Daytona Grey Avant
gdavison
Post by gdavison » Mon Aug 20, 2012 6:47 am
salamanzer wrote:I'm in the south west.... i may be able to find someone local.... or absolute worst case a stealer....
the "other" forum has a Vag-Com availability map on it
I did the battery mod on mine, as well as vehicle in motion for the DVD
salamanzer
Post by salamanzer » Mon Aug 20, 2012 7:16 pm
Any thoughts on this being an issue?
"This looks to be the battery, if i was to swap it would i have any issues with dropping the power in the car whilst the batteries are swapped, the replacement battery cost is getting picked up by the supplying car dealership"
Jason
gdavison
Post by gdavison » Mon Aug 20, 2012 8:19 pm
salamanzer wrote: Seems the battery on the car is dying.... what is the best battery to replace it with? It seems to charge, but not hold on to it for very long.... after a while the boot stops opening and the engine to start is a bit lazy.... once the car is running everything is perfect.
I had this.. Battery was replaced under warranty by Audi
h t t p : / / a u d i s r s.com/about20145.html
