VAG option decoder
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
sonny
VAG option decoder
Post by sonny » Wed Apr 06, 2011 6:25 pm
Mr Footlong
Re: VAG option decoder
Post by Mr Footlong » Fri Nov 25, 2011 1:03 am
Going to try that in the morning, thanks!
/EDIT - Does exactly what it says on the tin:
E0A = No special edition
0GE = Emission standard EU3
4UE = Air bag for driver and front seat passenger
6XD = Exterior mirrors: electrically adjustable/heated
1KZ = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LJ = Disc brakes, front
2MC = Sports suspension with variable shock absorption
3FE = Electric slide/tilt sunroof with sun screen/sunblind
5TU = Decorative inserts, carbon with metal fibre
7X2 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
8GT = Compact alternator 90 - 150A
0G7 = Tiptronic
0YS = Weight range 17 installation control only, no requirement forecast
0JM = Weight category front axle weight range 12
T09 = 8-cylinder gasoline engine 4.2 L unit 077.A (aluminum)
3NZ = Rear seat bench unsplit, backrest split folding
8EC = Bi-functional headlight with gas discharge lamp, for driving on the left
U1D = Instrument insert w/ mph speedo, clock, tachometer, trip odometer and additionalinstruments (voltage, oil temperature)
X2B = National sales program Great Britain
1N1 = Power steering
1XY = Leather trimmed multi-function sports steering wheel w/ Tiptronic
3HK = Alcantara scope without leather
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q2 = Multi-function display/on-board computerwith check control
8Z5 = Not hot country
D0V = 8-cyl. gasoline eng. 4.2 L/331 kW 40V V8biturbo base engine is T09
7Q2 = Navigation system with color screen
CL5 = Alloy wheels 8.5J x 18
7K1 = Tire pressure warning light
4X3 = Side air bag front with curtain air bag
VJ4 = Reinforced bumpers
6R0 = Selector lever cover
3L5 = Electric seat adjustment for both front seats
VW1 = Side windows tinted green, from B-pillar to rear window gray tinted safety glass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SA = Without additional engine guard
Q1E = RECARO sports seats, front
4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicle identification number
Current:
Gone:
Trups
Trader (Expired)
Post by Trups » Sun Aug 19, 2012 8:45 pm
Awesome that is. nice find.
0GG = Emission standard EU4
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
6XL = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
5SJ = Left exterior mirror: convex
6TS = Right exterior mirror: aspherical, large viewing field
1KJ = Disc brakes, rear
1LM = Disc brakes, front
1X1 = Four wheel drive
3FA = Without roof insert (standard roof)
5MR = Decorative inserts
7X8 = Park distance control, front and rear with rear view camera
4R4 = Power windows with comfort operation andcircuit breaker
8GH = Alternator 190 A
0G7 = Tiptronic
0YK = Weight range 10 installation control only, no requirement forecast
0JN = Weight category front axle weight range 13
TT7 = 10-cylinder gasoline engine 5.0 L unit 07L.B (aluminum)
U0F = Instrument insert with tachometer clock and mph speedometer
1N3 = Speed-related variable steering assist (Servotronic)
2FU = Leather trimmed multi-function sports steering wheel w/ Tiptronic
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
9Q4 = Multi-function display/on-board computerwith check control
D70 = 10-cyl. gasoline eng. 5.0 l/426 kW (40V)V10 FSI BIT Base engine is TT7
CY6 = Alloy wheels 9.5J x 20
7K3 = Tire pressure control, frequency 433 MHzhigh level version
4X4 = Side air bag, front and rear with curtain air bag
VJ3 = Reinforced bumpers
3L4 = Electric seat adjustment for both front seats, drivers seat with memory system
S0C = Introductory volume
4KF = Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
4K2 = Radio remote controlled central locking "SZV"
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
Q4Q = Sports front seats
4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
WhiteKnight
Post by WhiteKnight » Tue Nov 12, 2013 6:35 pm
There is an Audi option code calculator that I came across sometime ago. Will see if I can dig it out from the other forum.
WhiteKnight
Post by WhiteKnight » Tue Nov 12, 2013 6:55 pm
As OP
http://igorweb.org/equidec/Default.aspx
simply type in the code and then click 'decode'
only suitable for up to 2012 VAG vehicles but may work with some later ones. :thumbs:
could handy threads, topics and how too's like these be made in to 'Stickys' under a column titled Knowledge Base.
Submitted by forum members based on their findings and experiences and regulated/locked by the moderators ?
zainster
Post by zainster » Fri Mar 04, 2016 11:38 am
You can use the 3 digit PR Codes found inside the Service book to find out all the options on your car here ...
http://prsearch.planetvag.com/
Current: None
Previous Audis: B9 RS4 Avant, B7 RS4 Avant, Mk3 TTS, Mk1 TT Quattro Sport 240
liffy99
Post by liffy99 » Sat Jan 14, 2023 12:33 pm
Difficult to grasp this. I’ve looked at my codes ( similar to the second entry above) but so much seems missing. No mention for example of the HUD, Bang & Olufsen, Sports exhaust and more that my RS5 has ?
What do the other codes ( in larger type on the options Sticker ) mean, such as DECA .
F53 on mine says 18” wheels, but mine are 20” . . .
thedonman
Post by thedonman » Wed Oct 23, 2024 2:15 am
Mine shows weird stuff too, especially for newer options.
Return to “Audi S and RS Ownership”
Users browsing this forum: No registered users and 9 guests
