Power Loss B5 RS4(UPDATE)
2.7 V6 30v biturbo - 380 bhp
JJ-RS4
Post by JJ-RS4 » Thu Jul 05, 2012 5:19 pm
I just bought a 2001 RS4 and It did not feel faster than my E36 3.2 M3 so I took it to the dyno.
It made only 352hp and 449nm. :shock: The car has remap and exhaust with decat. It has 228000km.
What are the possible causes of lack of power? I was expecting something around 400hp.
The timing belt service will be done shortly. What to look for?
neckarsulm
Re: Power Loss B5 RS4
Post by neckarsulm » Thu Jul 05, 2012 10:15 pm
Where does one start?
EGT(s)
MAF
Do a Vag Com scan and post the results.
If there are no codes, do a live data run with VCDS logging MAF and post here
JJ-RS4
Post by JJ-RS4 » Wed Jul 25, 2012 9:26 am
There are too many fault codes that we have detected.
16524 Oxygen Sensor B1 S2
P0140-35-10- No activity-ıntermittent
17861- Exhaust Gas Temp Sensor 1 (G235)
P1453-35-10- Open or Short to plus- intermittent
17521-Oxygen Sensor; B1 S1
P1113-35-10 -İnternal resşstance too high- intermittent
17547 Fuel Trim: Bank 2 ( Add )
P1139 -35-00 System too rich
17545 Fuel Trim: Bank 1 ( Add )
P1137-35-00 System too rich
17537 Fuel Trim, Bank 2 ( Mult )
P1129-35-00 System too rich
guy
Post by guy » Wed Jul 25, 2012 12:45 pm
Looks like replacement EGTs and a Maf as well as the Cambelt service! Have the lambdas ever been changed?
B5 RS4 - Misano, (fastest colour!!) - weekend runner
S3 - red, kinda orange though! - SOLD
A3 TDi - Black - SOLD
oh and a fiesta 1.25 zetec daily runner!!
JJ-RS4
Post by JJ-RS4 » Thu Jul 26, 2012 2:58 pm
I will try to change them as soon as possible.
I have no clue ıf lambda sensors have been changed or not...
neckarsulm
Post by neckarsulm » Fri Jul 27, 2012 7:15 am
Definitely EGTs, a fault with those will reduce boost
Lambda faults don't tend to reduce power in the short term
JJ-RS4
Post by JJ-RS4 » Tue Jul 31, 2012 10:52 am
neckarsulm wrote:Definitely EGTs, a fault with those will reduce boost
Thanks for the info. Do I need to replace both of them.....It seems that one of it is faulty??
Those things are really expensive :(
Mr V10
Post by Mr V10 » Tue Jul 31, 2012 2:42 pm
JJ-RS4 wrote: Those things are really expensive :(
Welcome to RS ownership. :thumb:
neckarsulm
Post by neckarsulm » Tue Jul 31, 2012 10:14 pm
you can replace just the faulty one (unlike turbos)
JJ-RS4
Post by JJ-RS4 » Fri Aug 10, 2012 5:01 pm
:biggrin3:
JJ-RS4
Post by JJ-RS4 » Fri Aug 10, 2012 5:05 pm
neckarsulm wrote:you can replace just the faulty one (unlike turbos)
Hi,
One of my friend will come from Germany this month. I will order the EGT repair kit and MAF. As he will bring the parts, I will ask him to get another things....for example: Set of spark plugs? Anything else?
JJ-RS4
Re: Power Loss B5 RS4(UPDATE)
Post by JJ-RS4 » Sat Sep 15, 2012 7:21 pm
MAF-EGTs and spark plugs were changed by new ones....fuel trim and EGT fault codes were all been cleared. The vehicle seems to operate better than before as well as less fuel consumption. But we have a new problem.....when the engine is on boost about 5000rpm, It sometimes feels sluggish and cuts power suddenly....the car behaves like a NA 2.0 rather than 2.7T.
We took the car to the mechanic where the parts were installed and diagnosed it. Fault codes are right below. The car has decat.
16815/P0431/001073 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
17521/P1113 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
I am not sure these faults are really effective on performance cut, the car has decatted as I mentioned.
This is the last fault code and most suspicious !!!!
17964/P1556 - Charge Pressure Control: Negative Deviation
As I searched for the fault code, I got some info from the net.
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too Low
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzle
Has anyone faced with the same problem? What to look for initially? Leaks or N75?
Thanks for your help :bowdown:
MrGeneric
Post by MrGeneric » Sat Sep 15, 2012 9:16 pm
N75 valve... Had same prob and dough changed it and it was fine... Is the n75 also know as boost pressure sensor?
Users browsing this forum: No registered users and 62 guests
