Downsized my tyres, at last !
2.2 I5 20v turbo - 315 bhp
dave1
Post by dave1 » Mon Jul 26, 2004 9:02 am
Rob mate.
Get your tyres changed now! That cracking on the sidewall will result in your tyre departing from the wheel. When you get them changed inspect the sidewall corners and you will see that the tyre structure is split at the radius. It happened to me. read my 'some info for you'. I changed mine a month ago. My spare still had the 245 SP on it and that was narrower than the 225 by about 4-5 mm. The Audi dealer is wrong. I will give you my car if i am wrong.
Rob20vurq
Post by Rob20vurq » Mon Jul 26, 2004 8:05 pm
Thanks Dave will do!!!!!
afhgus
tyre size?
Post by afhgus » Thu Aug 05, 2004 7:26 pm
:twisted:
I read your tyre debate with interest as I presently have dunlop 9000's 245's on the back and the size down 225's on the front. These 225's have been recommended as you know by dunlop as the correct tyre to now fit. I like the feedback from them but am debating to try some 235's (pirellis,michelins etc) as a compromise between those uber looks of fat tyres and the sensibe choice of smaller cheaper and safer tyres. But MCP told me unless you drive like a luny 245's are the right choice. Is anyone as muddled as me!?
robo
Post by robo » Thu Aug 05, 2004 8:31 pm
Hello afhgus
Get the tyres changed now if dont do it your dif will not last long.!!
just cant get enough of it
DAVIDP20V
Post by DAVIDP20V » Thu Aug 05, 2004 11:45 pm
agree qith robo, do it asap ! rolling radius is wrong with all wheels being driven together. diff will say goodbye soon
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
afhgus
Post by afhgus » Fri Aug 06, 2004 6:20 pm
Don't worry about it boys. I have followed the advice of QST whom I trust. How about 235 size tyres as a comprimise though?
AAH!
Post by AAH! » Sat Aug 07, 2004 3:06 am
The collected wisdom of most long term RS2 owners from most of the RS2 forums on the net is to use 225/45/ZR17 tyres.
A few years ago, after reading the experiences of many RS2 owners, I changed from 245/40/ZR17 Perelli P-Zero's after endless (dangerous) side wall problems to 225/45/ZR17 Goodyear Eagle F1 GS-D3's and have not had a single side wall problem since, but have had substaintially improved and sharper cornering with much more feel.
The brand choice is up to you but going with 225/45/17's is a must.
Angus
RS2 +
afhgus
Post by afhgus » Sat Aug 07, 2004 2:06 pm
thanks for the advice. I think thats the sensible choice!
M690LYY Volcano black,130000 miles,standard,everyday transport, new rear discs, new door trims, replaced radiators x2, front/rear shocks(OE) + suspension bushes, recent alarm, undersealed, new exhaust/head gasket, pulls like a train. for sale soon
Pete_RS2
Post by Pete_RS2 » Thu Aug 26, 2004 10:13 am
I need to get some new front tyres but have a dilemma as the rears are almost brand new 245/40 Dunlop SP9000's. I guess I will just have to get 245/40's for the front and downsize when all four need replacing together.
I guess it's also OK to use tyres which have W (not exceeding 168 mph) & Y (not exceeding 186 mph) ratings in addition to the Z rating ?
Has anybody ever used Yokohama S1-Z tyres ?
'95 Volcano Black RS2, MRC remap, Samco turbo hoses, S3 DV, Jetex panel filter, xenon HID headlights, LED sidelights & dashlights, clear side repeaters, VDO boost gauge, remote locking kit, Blaupunkt MMC mp3, Uniroyal Rainsports
scillyisles
Post by scillyisles » Thu Aug 26, 2004 11:12 am
It's not OK to use the car with Dunlop SP9000 in 245/40ZR17 size - speak to Dunlop technical support - they'll be horrified that you've got these tyres fitted on a 7 inch rim. This tyre is heated up during the production process to 8.5 inches and as such you're putting tremendous strain on the sidewalls of the tyre by fitting it on a 7 inch rim. I also believe your insurance company would take a very dim view if you had an accident with these tyres fitted.
I had exactly the same issue with my car when my Audi dealer fitted 5 Dunlop SP9000 tyres on the car - after checking Audi dealer apologised profusely and fitted a replacement set of 225/45 ZR17 Bridgestone tyres.
Tyre markings are rather confusing - the old Z style marking merely means that the tyre is rated at speeds over 150mph but it does'nt really tell you how much. The newer W and Y ratings attempt to clarify this - W= rated up to 168mph Y= rated up to 186mph. The other thing about tyres that's relevant to the RS2 is the load index - because the RS2 is relatively heavy it needs a tyre capable of carrying this load at speed - I think you need to be looking at tyres that are rated at 91 or higher.
Audi RS2 - the original
Pete_RS2
Post by Pete_RS2 » Fri Aug 27, 2004 10:12 pm
I did speak to Dunlop technical support today & they said it was unsafe to use 245/40ZR17 & strongly recommend that I ditch the virtually new SP9000's ASAP. So I'll probably eBay them & downsize in the next few days.
scillyisles
Post by scillyisles » Sat Aug 28, 2004 12:14 pm
Pete_RS2 wrote:I did speak to Dunlop technical support today & they said it was unsafe to use 245/40ZR17 & strongly recommend that I ditch the virtually new SP9000's ASAP. So I'll probably eBay them & downsize in the next few days.
Yes this is exactly what happened to me - I had to ditch 5 SP9000 tyres that had only done 1000 miles - luckily in my case the tyres had been fitted by my Audi dealer so they stumped up the cost for five new Bridgestone tyres.
At the moment Kwikfit are doing an offer on Pirelli tyres - 3 for the price of 4 (I suppose they'll do the same percentage on 5) this is a great deal. Unfortunately, Pirelli's best performance tyre the Nero is'nt available in 225/45ZR17 but the Pirell Pzero Rosso is. If you don't like Pirelli then next month the offer from Kwik Fit is on Continental tyres. Hope this helps.
Cobstar
Post by Cobstar » Tue Aug 31, 2004 12:08 pm
Hi Pete
I'm glad to hear that you've decided to downsize - although it's a pain having to take off nearly new tyres - safety has to come first.
Mine came with a virtually new set of tyres which I didn't realise till afterwards shouldn't have been fitted. Definitely been a steep learning curve with the RS2 :lol:
Kim at QST pointed out that he wouldn't have used that tyre, in that size, on the car and suggested replacing them after 5,000 miles. I ran them longer but always had trouble keeping the pressures at the right level - had to have one resealed to rim. Then had a puncture - fortunately spotted as I opened the gate up to a farmyard - and when the nice guy from Ontime took the tyre off found the tread had split from the wall along the inside edge. Thank goodness I wasn't having a razz along the motorway when that happened.
Pete_RS2
Post by Pete_RS2 » Thu Sep 16, 2004 8:07 pm
I've just switched to Uniroyal Rainsport 225/45ZR17's. £368 for 4 from my local Just Tyres branch. I didn't realise the front wheels were 7J & the rears were 7.5J width though ???
scillyisles
Post by scillyisles » Thu Sep 16, 2004 9:03 pm
Pete_RS2 wrote:I've just switched to Uniroyal Rainsport 225/45ZR17's. £368 for 4 from my local Just Tyres branch. I didn't realise the front wheels were 7J & the rears were 7.5J width though ???
RS2 has 7 inch rims front and rear.
Users browsing this forum: No registered users and 13 guests
