Apgrade discs?
2.2 I5 20v turbo - 315 bhp
robo
Apgrade discs?
Post by robo » Sat Jul 10, 2004 7:57 pm
Hello I've tryed to do my front brakes upgrade today, got all bits ( 993 turbo calipers, 993 322x32mm discs and pads), the only problem i had i think was the discs they not deep nuf, has any one done upgrade them selfs, do you know corect porsche part number for front discs 322 x 32 mm?
Can any one help plz.
Thanx.
just cant get enough of it
Jani
Post by Jani » Sat Jul 17, 2004 12:06 pm
You need discs from 928GT or GTS with deeper disc hat. That should fit. Plus the caliper air removal valves need to face up, I think 911 calipers they face down. Can be switched.
robo
Post by robo » Sat Jul 17, 2004 1:32 pm
I have switched valves they facing up now but discs are of 993 turbo and as you set hat is not deep nuf.
Thanx Jani for this Very Very important info,
Thanx again m8
odysseyireland
Post by odysseyireland » Sun Jul 18, 2004 11:02 pm
I am looking at an RS2 that has had brake discs changed to cross-drilled items from a 944 Turbo which current owner says work well (it was a previous owner that changed them), roughly same size as std RS2 discs but drilled.
Are these similar to the 928GT ones mentioned above?
:greyrs4:
robo
Post by robo » Sun Jul 18, 2004 11:14 pm
odysseyireland wrote: Are these similar to the 928GT ones mentioned above?
I hope not , I need 928gt to be 322mm, 944t and rs2 are 304mm.
odysseyireland
Post by odysseyireland » Mon Jul 19, 2004 9:28 am
so the 944 Turbo ones are a good enough replacement, same size but cross-drilled. Not as good as the larger discs obviously, but a little better than standard.
:greyrs4:
Jani
Post by Jani » Tue Jul 20, 2004 8:27 am
I'm not sure whether 928GT had 322mm brakes, the GTS I'm quite sure did have these -with the right offset for RS2
robo
Post by robo » Tue Jul 20, 2004 9:09 pm
928 GT is 304mm 928 GTS 322mm but they dont do them cross-drilled.
Finaly i have finished the upgrade, feels GR8 , 993 turbo big reds with pads and 928 gts 322mm discs, not recomended to DIY due to no part numbers.
