severe misfire at idle
Re: severe misfire at idle
Where did the new coilpacks come from?
stealthyspeeder
- 1st Gear
Ok so did a scan for fault codes and only got
16486 - mass airflow sensor (G70) P0102 -002 signal too low
and
17481 mass airflow sensor 2 (G246) P1073 -002 Signal too low
As you would expect with the MAF's removed!
Also I noted there were no missfres at all, gave her a few revs when she warmed up and didnt hear/feel any there either (VCDS had the misfire counter disabled when there was throttle)
No regarding the coil packs, the ones that are in the car right now are the ones that were in it when I bought the car. They have been grand so far, the only reason I attempted to change them was because I thought that as the car still had a tiny jerk in its idle when it was cold (like were talking about being a perfectionist here), most people wouldnt even notice it! I have no suspision about these ones that are in it now, the new ones, I will nip down and find the brand and model now.
and
Last edited by stealthyspeeder on Fri Jul 06, 2012 8:49 pm, edited 1 time in total.
stealthyspeeder
- 1st Gear
OK so I have 8 of these new one, this is one of them
http://www.en.bremi.de/produktdetail?artnbr=20130
Last edited by stealthyspeeder on Fri Jul 06, 2012 9:02 pm, edited 2 times in total.
it's a really odd one.
Did you change the coil packs with the ignition on?
Maybe you have got an air leak after all. I would be tempted to remove the MAFs from the airbox and slot them in individually to eliminate the possibility of a leak around them.
stealthyspeeder
- 1st Gear
No I had the ignition off when they were changed.
I will try seating the MAFs without the airbox tomorrow morning!
What is strange if the problem is airflow or vacum related, is that the MAF values when it was missfiring looked normal???
Yes, they weren't wildly off. Maybe a bit on the low side. Did you torque up the plugs? Were they the right ngk ones? Can't remember now.
Hats off to you Shop. This is what having an enthusiast community is all about!!
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
+1
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Yeah, shame it was a bit too early to celebrate.
Come on, stealthy, let's get diagnosing.
What does the fuel trim vales say? If they have a high correction factor you may have a vac leak that isn't showing up on the maf readings.
Problem is to get the trim values he's going to have to drive it for a while, and I don't think that's a good idea.
Also, a vac leak that would cause such poor running would be huge and the MAF readings wouldn't be showing such coherent values.
stealthyspeeder
- 1st Gear
Ok, so so I put the box back on with the MAF's, and let her warm up. It wasnt pretty, but when she warmed up, misfire was cured at idle.
I thought this is good, lets take her out and see what codes she gets. Did a couple of miles, the problem is not noticeable when driving except when stationary in D with the foot on the brake, there is a rough idle that can be felt and seen at the rev counter.
so scanned up when I got back and had
18393 - Coolant Control Module 2 (J671) , P1985 - 002 - Malfunction
18308 - Coolant Fan Control 2 , P1900 - 004 - Open or Short to Ground - Intermittent
as engine code errors. (I have had the 1st one before - http://forum.rs246.com/viewtopic.php?f=2&t=90067) but I beleive it was resolved when some corroder coolant pipes were replaced.
Now when returning and parking up, the idle was at about 1200 rpm. When the errors were cleared, idle returned to 900rpm and if left for a minute or so it would suddenly go back up to 1,200, and the error code returned.
So.....
Current facts,
Car idles perfectly in closed loop (no MAFS) revs fine too - also it ran fine after service last Saturday (so I think the plugs are not the issue - I cant find the reciept or boxes though
Car runs like a pig until up to temperature (MAFS connected)- then problem is considerably less (however still present)
1 error and one intermittent error after a drive.
Cars idle is affect by coolant error message once warmed up
Any help/ideas are much appreciated! Especially you from you Shop!
So.....
Current facts,
Closed loop is when the car is using the info from the mafs and lambdas to adjust the mixture. When you unplug one of them the car uses safe default fueling value - that's why your car seems to run ok when they are unplugged.
If you can drive the car, let's do what adsgreen suggests and look at the trim. Don't reset fault codes - this will zero the trim values. Drive it for a few miles then do the same log you did initially.
Did you try just the MAFs without the airbox?
Did you unplug any injectors?
Can you retorque the plugs (after removing one to check what they are).
Users browsing this forum: No registered users and 178 guests
