Dimensions RS4 B8 v B7
4.2 V8 32v FSI - 444 bhp
Andyuk911
Post by Andyuk911 » Tue Jul 03, 2012 5:31 pm
I had a look at the changes ...
B7
Length 4586
wheel base 2651
nose to centre of front wheels 934( so the B8 has less weight forward of the wheels))
B8
See pix and ... :-
Length: 4719mm
Height: 1416mm
Wheelbase: 2813mm
Width: 1850mm (without mirrors)
Luggage capacity: 490 litres (rear seats up), 1430 (rear seats folded down)
Unladen weight: 1795kg
Engine oil capacity: 10.7 litres
Fuel tank: 61 litres
Turning circle: 11.9 metres
RS4 Avant - Sold Aug 2009
stu
Re: Dimensions RS4 B8 v B7
Post by stu » Tue Jul 03, 2012 5:46 pm
I had a B8 TDI Avant for two weeks and to me it felt even bigger than the numbers state, particularly forward of the driver.
Nickyboy
Post by Nickyboy » Tue Jul 03, 2012 9:24 pm
Odd my B8 S4 felt smaller than my octavia VRS but is actually bigger.
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Condor24
Post by Condor24 » Thu Jul 05, 2012 6:53 am
The length of the B8 is now marginally less than the C5 RS6, although the wheelbase of the B8 is greater than the C5.
Verification would be appreciated in case I am using the wrong measurements.
:beerchug:
"Understated uber wagen speaks loudest'
2003 Avant Daytona Grey owned from new. 64k miles of September 2018. Bilstein shocks / Hotchkis AR / Brake upgrade
Audi RS6 C6 Avant MTM Stage 1 & Miltek Sold
Audi RS4 Avant B5 Sold
Audi S4 B5 Avant 6 spd Sold
Audi S2 Coupe 230 bhp 6 spd Sold
Brooner
Post by Brooner » Thu Jul 05, 2012 7:38 am
Feck that could be tight to fit my garage as builder thease days give you the smallest garage thaey can get away with my B7 just fits with enough room to squeese out of the car when it in
P_G
Post by P_G » Thu Jul 05, 2012 8:35 am
Same with me but length wise. With the front touching the padded wall I have 15cm clearance between the rear of my B7 and the garage door when shut and that is 13cm longer. Squeeze!
R8 it is then.... :sekret:
Brooner
Post by Brooner » Thu Jul 05, 2012 10:51 am
P_G wrote:Same with me but length wise. With the front touching the padded wall I have 15cm clearance between the rear of my B7 and the garage door when shut and thaat is 13cm longer. Squeeze!
Sounds like a sencible option :biggrin3:
adsgreen
Post by adsgreen » Thu Jul 05, 2012 7:25 pm
Not so sure that the distance from the front wheels will make that much difference. Depends on whats there but from memory the B7 has alot of "styling" with not much substance. Wouldn't take a huge amount of frnt end redesign to change that without affecting the front end weight.
Users browsing this forum: No registered users and 155 guests
