Metal on concrete
2.7 V6 30v biturbo - 380 bhp
Petoir
Metal on concrete
Post by Petoir » Sun Jul 11, 2004 6:46 pm
Hi,
A couple of weeks ago I had the milltek cat back system installed on my RS4 - now it sounds like a real car. I love it, but the system is a little wider on girth and seems to catch in multi storey's and speed bumps more than the standard pipes, which in this country as you know means lots of teeth clenching, steel grinding moments.
Next upgrade is the MTM stg1 and gmbh suspension, but wondered what other RS4s drivers experiences were with lowered suspension and cat back system with a couple of people in the back? After driving an Evo 6 for two years I really want do something about this standard suspension setup but not to the detriment of practical stuff, like not getting beached in car parks with the wife, kids and shopping.
Pete
kiwi_mtm
Post by kiwi_mtm » Sun Jul 11, 2004 7:12 pm
I recently did the Quattro GmbH. MUCH BETTER than Stock. I was always left disappointed with the Stock Suspension. Now i just smile.
So far, if i'm careful, I dont really have any problems with the new lower height.
Mog
Post by Mog » Sun Jul 11, 2004 7:33 pm
Are you sure that the threads on the "U" bolt clamps on the exhaust are turned upwards and not down as they will effectively lower the car by about 1" if so.
Mog :nogarors4:
2009 Focus RS
2006 Subaru Forester STi..440bhp
simple1
Post by simple1 » Mon Jul 12, 2004 12:33 am
Mine also seems to ground in carparks, but only on speed bumps. Usually just after the front wheels have cleared, I take it easy but happens quite regularly, has always done this, standard or Miltek systems. I put it down to shot front suspension :piss: Will have to invest in some decent suspenders soon :biggrin3:
kennyboy
Post by kennyboy » Mon Jul 12, 2004 8:12 am
Mine only grounded on those pyramid speed bumps, I now go over these with one wheel riding over the bump. Been in multi-storey car parks and grounding has not been an issue.
The bolt on the clamp on mine is facing down IIRC (bolt head at top with nut at the lower end with remaining bolt protruding). If this becomes a problem, turning it around will gain at leat 10mm ground clearance.
The GmbH (20mm drop) will be an issue I think i.e. having to go at a snail's pace, rather than going at 'slower than normal' speed bump pace. I would favour the H&R kit with height adjustment.
No sig, no RS4 anymore
PhilT
RS246.com
Post by PhilT » Mon Jul 12, 2004 8:28 am
With the GmbH Suspension and Sportec exhaust, you have to proceed with caution over all obstacles. Gets on my nerves, have to avoid all speed bumped roads.
I'm up for some more suspension too, the GmbH has only lasted 20k miles.
S4power
Post by S4power » Tue Jul 13, 2004 8:05 pm
With the quattro GmbH suspension and the quattro GmbH exhaust, I have never had any ground clearance issue with ordinary speedbumps. :nogarors4:
/Thomas
