Vcds ordered
brn7y
Vcds ordered
Post by brn7y » Thu Jun 28, 2012 8:30 am
Just ordered a cable from Ross-Tech, should be with me next week.
What are the essentials to do first and any other tips.
adsgreen
Re: Vcds ordered
Post by adsgreen » Thu Jun 28, 2012 9:14 am
Rns-e rs4 logo :)
Check logs / stored codes.
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Thu Jun 28, 2012 6:37 pm
Enabling window open/close on remote press (can also close sunroof on remote but not open it).
Enabling rear lights on when DRLs on.
Changing pitch and volume of parking aid so that difference in pitch between front and rear warnings is more obvious.
pDkALO
Re: Vcds ordered
Post by pDkALO » Thu Jun 28, 2012 7:07 pm
Disabling the "press clutch to start" message in the DIS, so you can go through computer data with ignition on but without need to fire up the engine
And opening and closing the RNSe screen at the click of a mouse - completely pointless but just makes me smile! (yes, I probably should get out more....)
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Thu Jun 28, 2012 7:20 pm
DALO wrote:Disabling the "press clutch to start" message in the DIS.
Tell me more...
pDkALO
Re: Vcds ordered
Post by pDkALO » Thu Jun 28, 2012 7:34 pm
I can't remember exactly where it is - I stumbled across it whilst tinkering - pretty sure it's tucked away somewhere in the adaptation channels, possibly in the instruments module. I'll plug in tmrw and see if I can remember. Very handy tweak IMO.
pDkALO
Re: Vcds ordered
Post by pDkALO » Thu Jun 28, 2012 10:31 pm
I've just checked - it's in the coding of Module 17 - Instrument Cluster (J285)
Remove 16 from the 3rd & 4th digits and the "press clutch pedal to start engine" nanny reminder will vanish and you'll get the normal DIS display when the engine's off. In the coding guidance it's described as "+16 = clutch pedal switch operation in FIS display".
As standard the coding in mine was 0023418, so I changed it to 0007418, job done.
And while I was in module 17, I ran the output test again, just so I could watch the needle sweep - I soooo wish it could be made to do that on start up!!
Scatman
Re: Vcds ordered
Post by Scatman » Fri Jun 29, 2012 7:54 am
Enable the rather subtle alarm blip when you lock the car
HEo2TEC
Vcds ordered
Post by HEo2TEC » Fri Jun 29, 2012 8:11 am
I would love the needle sweep.
brn7y
Vcds ordered
Post by brn7y » Fri Jun 29, 2012 9:36 am
Liking the drl's rear lights idea, handy for dull wet day in Scotland.
brn7y
Vcds ordered
Post by brn7y » Fri Jun 29, 2012 6:48 pm
Getting no response from controller error when trying to access navigation
pDkALO
Re: Vcds ordered
Post by pDkALO » Fri Jun 29, 2012 8:36 pm
brn7y wrote:Getting no response from controller error when trying to access navigation
Access the RNSe through the radio controller module
brn7y
Vcds ordered
Post by brn7y » Fri Jun 29, 2012 10:44 pm
Nope, still no joy.
Timster
Re: Vcds ordered
Post by Timster » Fri Jun 29, 2012 11:06 pm
HEo2TEC wrote:I would love the needle sweep.
+ 2
... but it can't be done on the B7.
brn7y
Vcds ordered
Post by brn7y » Fri Jun 29, 2012 11:15 pm
PetrolDave wrote:Enabling window open/close on remote press (can also close sunroof on remote but not open it).
1 done
2 done
3 how?
Users browsing this forum: Bing [Bot] and 115 guests
