Wing Mirrors
Wing Mirrors
Do the standard RS3 Wing Mirror fold - and if so how ?
- Dave_Hedgehog
- 5th Gear
Wing Mirrors
Electric folding is a cost option
Otherwise it's brute force
The Hedgehog, creator of RS4.org, back in of the RS fold yet again, third time lucky
Re: Wing Mirrors
Well mine are electronically adjustable, and heated - but how do you make them fold in ?
Bacardi Jo
Re: Wing Mirrors
there will be a setting in the MMI just tick the box
Re: Wing Mirrors
There will be a setting on the mirror switch, if you have them then the switch will rotate to the 6 o'clock postion, ie the bottom (If heated mirrors is 12 o'clock, right mirror 1 o'clock and left mirror at the 11 o'clock postions)signum wrote:Well mine are electronically adjustable, and heated - but how do you make them fold in ?
Wing Mirrors
MMI?!! Ha ha, it's a bit behind those times!
Bacardi Jo
Re: Wing Mirrors
my mistake didn't realise no mmi.
Re: Wing Mirrors
That description does not mean they fold, it just means that you don't have to stick your hand out the window to adjust them. They need to be 'electronically adjustable, heated and folding' or some similar description to have the feature you are asking about.signum wrote:Well mine are electronically adjustable, and heated - but how do you make them fold in ?
The sure way to tell is to look at the mirror adjustment control. If you can rotate it through 360 degrees then your mirrors should fold (and will at the 6 o'clock position). If the rotary control only moves through 90-120 degrees then they are not the folding units.
Re: Wing Mirrors
PU7 Light/rain sencors/Auto dim RVM
6XJ Ext mirrors electric/heated/dim
So they don't fold....
Re: Wing Mirrors
I paid extra for folding mirrors and they forgot to fit them.. the cars been back to Audi and it they installed them so you should be able to get them retro fitted if you wanted
Current - 2011 Sepang TTRS - Milltek Secondary cat deletion pipes - S-Tronic Bangs
Gone by not forgotten - 2012 Ibis RS3 - Damn coolant issue.
Users browsing this forum: No registered users and 20 guests
