I currently have drilled and grooved discs (supplied by Audi), braided lines and running EBC Red Stuff. I have always found Ferodo DS2500s to be excellent in the past and would rate the red stuff as good as those. I now need new pads fairly soon, and a mate works for Listers so can get the Audi ones at cost - waiting on price but guess £40/£50 for fronts. I will be looking at £100+ for Red Stuff or DS2500s. What are the standard pads like? Any fade with regular hard braking? Any good braking from very high speeds?
Brake Pads for S4 - What are OE like?
Daytona RS6 saloon, KW v3s, Hotchkiss ARBs, Milltech non res, MRC
CI Granduca Motorhome!
Re: Brake Pads for S4 - What are OE like?
Can't comment on how they perform on the track, but they make a lot more dust than the Yellow-stuff ones I replaced them with
S5 Coupe, V8 on 20's with ContiSport rubber
How did you find their performance on the road?
I thought the Yellow Stuff pads were good, seemed to stop a bit quicker than OE but they didn't snatch so you could be subtle about scrubbing off speed without putting the other half's face into the dash
edited to avoid ambiguity
Very very dusty. I also now use EBC yellow stuff's and they're great for daily play. Can't comment on track use.
I was recommend not to use red stuffs due to the weight and power of the car.
•••MyProtein Discount code MP486494•••
ive been using EBCBrakesDirect for yrs.. v.good prices and delivery times:rich_5259 wrote:I thought the Yellow Stuff pads were good, seemed to stop a bit quicker than OE but they didn't snatch so you could be subtle about scrubbing off speed without putting the other half's face into the dash
http://www.ebcbrakesdirect.com/car/part ... 03-2008%29
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
2nd ever post
How easy to change the front pads? Easy (as I hope) or any little tricks or tools needed ??
many thanks
Guy
many thanks
Guy
