Sat Nav - mid Atlantic
Re: Sat Nav - mid Atlantic
Post by Shoppinit » Mon Jun 18, 2012 2:13 pm
Depends how many angry Porsche drivers are following me. :)
bilko1
Post by bilko1 » Mon Jun 18, 2012 7:41 pm
Shoppinit wrote:I believe the RNS-E has a FAKRA connector on it. Why don't you just get a new puck and put it in on top of the glovebox?
If you have a solar windscreen you will have to put it under the bonnet or it won't work very well as i found out.
Daveperc
Post by Daveperc » Thu Jun 28, 2012 3:34 pm
OK - many thanks to Marv8 for sending me a spare RNSE puck - but as Shop suggested below it has a different connector on it.
I am loathe to start trying to cut and splice cables etc - rather suspect the loss of screening etc would rapidly undermine the perfornmance, so still on the lookout for a replacement roof puck - hopefully that should be "Plug n Play!"
Dave
RS6JJL
Post by RS6JJL » Thu Jun 28, 2012 9:27 pm
got the same problem need a new antenna bought one off ebay not a roof one but the other type but it doesn't fit the standard head unit probably the plus head unit instead
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
Post by Shoppinit » Fri Jun 29, 2012 8:10 am
Dave, what's wrong with the part from Audi? Too expensive?
Why not get a sma puck on stick it on top of the glove box?
Daveperc
Post by Daveperc » Thu Aug 30, 2012 9:35 pm
Hi guys - sorry to resurrect an old thread - but this one is driving me nuts!
Asked MRC to swap the roof puck from my old car (now gone BTW) but when they got in there they found that the old car had three wires from the antenna assembly. On the new car however there were only two wires to be found!! The checked under the roof lining, down the back pillars etc - no where!!
So - Shopp - have you got a wiring diagramme which shows what wires there should be - and where they go?? It looks like someone has pulled one out.... Why???!!!
Dave
Post by chunky79 » Thu Aug 30, 2012 9:37 pm
Can't you just get a puck and stick it under the dash or bumper like shopp?
Daveperc
Post by Daveperc » Thu Aug 30, 2012 9:40 pm
Yes - dare say I could - but I want to find the missing cable first and see if just plugging it in solves the problem!
Dave
Post by chunky79 » Thu Aug 30, 2012 9:46 pm
Don't think the etka pic shows where the cables go. Sure shopp has posted it before
Post by Shoppinit » Fri Aug 31, 2012 7:38 am
Hi Dave, it looks like there can be 2 or 3 wires depending on whether the car has mobile phone prep option or not. All the Avant antennas have 3 wires coming out, but on the car side there may be only 2. Have you compared the option codes?
Either way, the GPS antenna wire will be there.
Daveperc
Post by Daveperc » Fri Aug 31, 2012 8:47 am
Bother - MRC fail!!
Yes, old car had phone prep, and this one doesn't! That explains the missing cable, and that was the reason that they didn't swap them over. Now the old car has gone, and I still have the problem. :cry:
I guess the assembly will be the same on any A6 (C5) Avant?? Maybe a trip to my local scrappie....
Dave
Post by Shoppinit » Fri Aug 31, 2012 8:54 am
Part number is 8L0 035 531E.
Same as any other A6 with navi.
Post by chunky79 » Fri Aug 31, 2012 11:29 am
Don't bother talking to the guys who have your old car, they are on cloud cuckoo land price wise
Daveperc
Post by Daveperc » Sat Sep 01, 2012 6:42 pm
Now I'm getting really confused!!
Decided that maybe a dash mounted puck was the answer so took a look on eBay etc. All the searches seem to suggest that the connector is a SMB (female) connector. In fact someone very kindly sent me a puck with this connector on already and I found it didn't fit
Problem is - my connector isn't SMB - It's something like a Wiclic (male) on the lead, and a female end on the back of the unit.
Did they make two different versions of the RNSD?? Could it have been "repaired" with a different connector?? The odd thing is that the aerial lead is all neatly bound into the harness etc and doesn't look like it's been messed with??
And suppose I just cut and spliced the cable - any reason why that shouldn't work??
Dave
Post by Shoppinit » Sat Sep 01, 2012 11:13 pm
There are 2 GPS sockets on the RNS-D. Not sure what the other one is.
Users browsing this forum: No registered users and 157 guests
