P_G wrote:
P_G wrote:
1. who said there's a cliff? I said the car goes flat. Those maha dyno'd cars look great. The first one goes flat. The second one is using such a ridiculous scale, the steepness in the curve is artificial.JCviggen wrote:I don't see that "cliff" that is supposed to be somewhere after 7K that you keep referencing...well running cars don't seem to have it.
There's insufficient data to go on, we can't see the gear or speed. Speed increases with RPM as well, so naturally more aerodynamic resistance and tire friction will make acceleration slow down the higher you go anyway (assuming power levels off or drops slightly)
That said, I can't make many statements about your particular car. Maybe it doesn't breathe as well at the very top as some others. I've seen some that definitely do not "slow down" dramatically above 7500... http://www.youtube.com/watch?v=mzbBRoIhODY
Do you know every RS4 on earth?
Your ET doesn't prove much, except that you got a stellar launch. What was the trap speed?
Have any vids (speedo preferably, not too interested in 1/4 runs)
Based on those plots (and your own) you still need to shift near the limiter to get the most out of it. If you short shift it you'll drop to a part of the power band where you're much worse off than at 8K. That's obvious from all the plots I've seen so far. That was my point...you however seem to think shifting at 7500 is better, I can't see a reason for that in the material so far provided.sakimano wrote: 1. who said there's a cliff? I said the car goes flat.
I have an RS6, doesn't mean I can't read power graphs. I didn't see it was a third gear pull, anyway, you can't draw any conclusions from 1 car, or 1 review for that matter.I'd love to see some of the data you've acquired on your own RS4.
Well you claimed yours was the fastest of the planet didn't you? If you meant "every RS4 I've seen a timeslip for" that's a small difference (less than 1% of the ones out there I guess)Why do I need to 'know' every RS4 on earth?
Speedo please!Any other video requests? I have a bunch.
I have very nearly as much information now compared to actually owning one. I would say data from multiple cars is more relevant than that from 1 car anyway.sakimano wrote:So you don't own an rs4 (thus haven't tested anything you're ranting about)
What? likeinvent quotes that I never made
faster than any other stock RS4 on earth
I'm not in the game of putting words in other people's mouths, if you feel wronged please be specific.Car starts to fall flat on its face at about 7500
That much is obviousLet's agree to disagree
That shows you just don't know what you're talking about. NHRA/IHRA tracks ALL calculate trap speed the same way. In fact the US based speeds are an average over the final section of the track, while the European 'dragstrips' use terminal speed, thus are HIGHER than US trap speeds. I use the term dragstrip lightly regarding European results...almost none are NHRA/IHRA certified other than Santa Pod...they are mostly runways with some temporary timing equipment setup. I wish there were more certified tracks because it's fun to compare the data. When you compare an NHRA/IHRA certified track's result to a non-certified track, you may as well compare to a guy holding a stopwatch and eyeballing the result. This gap between a European 'dragstrip and a proper certified dragstrip may also explain your perception of ETs being slower over there (although I don't see that) as comparing a prepared dragstrip to a random paved runway that has been abandoned is not going to yield the same traction/consistency. Again...those times 'don't count' other than to compare each other at that particular track. The NHRA/IHRA tracks can at least benefit from consistency and the certification standards that earn them that stamp. So compare Santa Pod times to US based times and you'll find things line up well.ETs are worthless to compare, especially european dragstrips never get near the ET's of the American ones, but trap speeds are similar.
What would be really useful is a dyno plot of your car, but I do consider dyno's to be a waste of money generally if all you're after is the numbers so I don't blame you if you didn't bother with that.sakimano wrote:as I said, you have nothing to go by but other people's dyno charts. I have my own acceleration testing, which I value far higher than other people's dyno charts. I could post a boat load of dyno charts showing RS4 who don't just go flat, but go negative. Again...I'd rather drive my car.
How am I supposed to know that you never filmed any 1/4 runs in the car or something like that?If you want to see a speedo video of someone doubling or tripling the speed limit, go buy an RS4
mustang dyno or dynojet. We could make it the first 3 that are done, then average the numbers.JCviggen wrote:On what dyno?
It'll probably make a drop over 300 on a MAHA and closer to 400 on the "right" dynojet...(subtract 50hp if the dyno has a hairdryer for a cooling fan)
Then you could have a muppet doing a run in 3rd or 5th instead of 4th which all gives different wheel numbers.
We'd really have to buy one
Users browsing this forum: No registered users and 13 guests
