hi,
my switchblade audi s3 key, remote has stopped working,i've changed the batteries but no joy,i'm using my spare at the moment,is there any where i can get it fixed as i guess it must be a electrical fault??regards Ryan
switchblade key
have you tried re-syncing it? This is for the S4
You will need BOTH of your "switchblade" keys to reprogram one or both of them.
Take the key you DO NOT want to program and put it in the ignition. Turn it one click forward.
Close and lock the drivers door with the second key.
On the second key (the one in the drivers door) press the 'UNLOCK' button ONCE only. The lights will flash on the car, but the doors will remain locked
With the second key still in the drivers door, unlock then lock the door again.
Pull the key from the slot and test remote functions.
Open drivers door, remove key from ignition.
If both of your remotes don't work, do the above for the first key, but on step #3, press the 'UNLOCK' button twice. The lights will flash twice, then continue on with step #4.
360bhp 342lb/t
