Water Leak
PatrickRS6
Re: Water Leak
Post by PatrickRS6 » Sat May 12, 2012 12:42 pm
Where's the AC drain located?
My passenger (LHD) carpet is wet, and when the AC is on, and i drive over a bumpy highway, the window gets foggy....
Driving off to Wörthersee 2012 in a few hours, so wo can help me out?
Re: Water Leak
Post by Shoppinit » Sun May 13, 2012 9:41 am
It's down where your clutch pedal would hit the carpet if you had one - bit closer to the center console in fact. I think someone posted some photos once - might even have been me.
But you peel the carpet back then you'll see the drain going through the bulkhead.
philroach
Re: Water Leak
Post by philroach » Sun May 13, 2012 10:05 am
Wet passenger carpet, points more to leaking rear screen washer pipe , or water coming in through bulkhead , either way unwed to get it sorted to avoid more problems with electrics under passenger seat !!!!
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Re: Water Leak
Post by Shoppinit » Sun May 13, 2012 10:14 am
Good point Phil, I had missed the bit where he said it's on the passenger side.
PatrickRS6
Re: Water Leak
Post by PatrickRS6 » Mon May 21, 2012 1:42 pm
It's on the passenger side, but i've a LHD car (guessing u guys in the UK have a RHD ;) )
I was @ Wörthersee the last week, so i've dried the floor, and didn't look again haha, will check this soon.
Drove as much as possible with the AC off to be sure.
Re: Water Leak
Post by Shoppinit » Mon May 21, 2012 2:54 pm
In that case, I take it back. :)
Users browsing this forum: Shoppinit and 87 guests
