There is a tick box on each empty page of the service book which is to be marked for any 'additional work' that has been done during a routine service. If you read the first few pages of the service manual it gives the details of the 'additional work' which has to be done on certain engines within the audi range at specific mileage intervals, it clearly says in this section that the cam-belt on the RS4 has to be done at 40,000 miles or 60,000 Km (which is nearer to 38.5k miles). S4 is at 80k.kennyboy wrote:I did think my service booklet was out of date/ wrong one originally supplied when it was registered. May be later cars comes with a revised service booklet with the relevant info.
Cambelt change
TarmacTerrorist
- 5th Gear
Too much is bad.
Plenty is better.
Plenty is better.
Ok, got it booked in for the 40k and belt.
Thought it would be prudent to phone around to see if the pricing varied for this job, guessed it would do a bit as labour rates are different throughout.
Result - a good laugh. The 40k service cost ranged from £380-£420; which was what I expected.
The cambelt ranged from £350 - £655! I asked for a breakdown of parts/labour in each case and it was all down to the amount of labour estimated. 2.9 hours to 5.5 hours to do the same job. They're all supposed to be reading off the same hymn sheet for these jobs so the only explanation is that they're looking at the wrong vehicle on their system.
By luck, one of the most reasonable prices was my local dealer (Harold Wood) so I have booked in with them. They want £380 for the 40k and £470 for the belt. They have confirmed it is a 3.5 hour job so I will make sure it's all in writing before I hand over the keys.
On another note, I enquired about doing the water pump at the same time (£41+VAT) as it will be nice and accessible. Is it worth it?
Ben
Ben
My personal view is.........do anything that may need done while you are doing something in the same area
If you had to fit a water pump at a later date and had to pay the same amount of labour again, you would be pissed off
My dealer suggested that the water pump was done while the belt was changed and offered to do it for the price of the pump
- SimonS4MTM
- Top Gear
- SimonS4MTM
- Top Gear
You might want to mention the ribbed belt as well. I am led to believe that this should be changed automatically when you ask for a cambelt change, however mine was not. I was a little bit annoyed, seeing as they take it off anyway.
This might help.... http://www.rs246.com/index.php?name=PNp ... opic&t=951
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Users browsing this forum: No registered users and 81 guests
