driving home from work yesterday, put my foot down expecting 20 'ish psi of boost instead it sat at 5 psi ! wouldnt go any furnther !!! help
i let it settle (drive without the turbo) try to give it some again and the needle on the boost gauge flys round to over 20 psi and away we go ! wtf !
so i though some weird glitch dont worry ! then it strikes again 5 psi wont go a snitch over. then goes away again
today driving everything seems ok till i get on to a dual carriageway heading home . floor it and 5 psi ! let off and let it settle, try again 5 psi !
any help would be much appreciated !!
within the last 2 weeks i did the maf cleaning trick to try an sort out a long term fault where the car stutters at WOT ! (which didnt fix the stutter prob) if this helps.
any ideas ? help me!
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
car is fixed !
main fault was spark plugs causing massive missfire !!
but changed/check whilst looking for fault were
1. fuel filter
2 d/valve
3 maf cleaned
4 vag com check (THANKS paul n from "s2forum.com")
5 wastegate diaphragm
6 wastegate frequency valve
7 spark plugs (sorted it) can you believe it !
1. fuel filter
2 d/valve
3 maf cleaned
Davidp20v
Users browsing this forum: Google Adsense [Bot] and 45 guests
