R3 front drilled discs....
2.5 I5 20v TFSI - 335 bhp
n5tews
Post by n5tews » Thu May 03, 2012 4:48 pm
All
The holes in the front discs are now completely blocked and the local stealer seems to think they can pressure wash them out. This has happened over the last six months gradually filling in the holes with some spirited driving sessions ;-))
Thought or advice much appreciated. I'm thinking new disc & pads.......
n5tew
PJC
Re: R3 front drilled discs....
Post by PJC » Thu May 03, 2012 4:50 pm
Any pics?
P_G
Post by P_G » Thu May 03, 2012 5:29 pm
Just get a hole punch or drill bit out and unclog them. Common B7 RS4 proceedure when using the soft OEM Pagids. If you want less dust and clogging go for EBC yellow stuffs or Ferrodo DS2500's if either are now aavailable for RS3 but I think they should by now.
Post by HYFR » Thu May 03, 2012 6:27 pm
my TTRS disc's filled up in less than 1 week
Dave_Hedgehog
Post by Dave_Hedgehog » Thu May 03, 2012 8:01 pm
P_G wrote:Just get a hole punch or drill bit out and unclog them. Common B7 RS4 proceedure when using the soft OEM Pagids. If you want less dust and clogging go for EBC yellow stuffs or Ferrodo DS2500's if either are now aavailable for RS3 but I think they should by now.
yellow stuffs was about before the RS3 as its got the same brakes as the TTRS :P
stu
Post by stu » Fri May 04, 2012 1:48 am
The compacted dust softens up quite a bit after a soak. I tried cotton buds on mine and it worked well - the cotton tip disintegrates almost straight away but the remaining plastic stick is a surprisingly good size/strength for the job.
n5tews
Post by n5tews » Fri May 04, 2012 1:08 pm
Any recommendations where to go for new pads?
RS6chris!
Post by RS6chris! » Sat May 05, 2012 11:10 am
Used to use a 4mm steel drill bit and cordless drill on my B7 RS4.
Worked a treat...
Tip...have a few 4mm drill bits as you WILL snap one or two!!!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Users browsing this forum: Google Adsense [Bot] and 14 guests
