Drive Train Stabliser
Has anyone got a AWE Tuning, drive train stabliser fitted to their car, if so does it make any significant differance?
I got one unfitted with my car and am deciding over wether to fit it or not
Cheers Jim
Cheers Jim
Stabilizer
For some people, it's not noticable. For myself, it made a noticable difference and I also have the APR snub mount installed. I hated the tranny slop. DTS and Snub cleared it up. Shub mount provides some of the same benefits and they are about $50.00.
DonP performed some tests on his vehicle using a DTS and Snub mount.
Take a Look. http://www.audiworld.com/tech/eng29.shtml
Richard
Richard
HI
I had the AWE stabiliser fitted by AMD a couple of weeks ago and I must admit it is one of the best mods I have had on my car. The whole car feels stiffer and is definitely more confident at high speeds and somehow it tracks better too.....I had the pleasure of driving up through Germany last week on the Autobahn
But it also makes gear changes so much smoother and if you have a short shifter it makes the box feel more tight and sporty as it removes the sloppy and somewhat loose feeling when changing up or down and you can relly feel the short throw.
Mik
Mik
I'd recommend it, it gives a noticeably better gearshift that a shortshifter alone and certainly reduces the 'rubber banding' in the transmission when going on an off the throttle or gearchanging.
It reduces the ground clearance slighly as it's lower than the standard gearbox brace. My car is lowered and it does scrape occasionally.
Pretty cheap too - relatively.
Fitted the DTS a couple of weeks ago, my verdict -
Fitting - Simple bolt on job, anyone with a good socket set and a bit of common sense could have this on in less than an hour. However due to sods law mine came with the wrong gearbox bracket (the possible reason why it was never fitted to the car), abit of careful measuring and two new holes soon had it on.
Perfomance - Ground clearance hasn't been a problem so far, it hangs about the same height as the plastic engine guard. Driving wise, the slight gearbox movement when hard on and off the gas in first gear has been eliminated, but apart from that i can't really tell any differance. Maybe its me but gearchange, stability and stiffness all seem the same as before.
Conclusion - Its certainly a good looking well made piece of kit and a nice addition to the car but don't expect any major transformations.
Jim
Jim
s4orce2001
i have Autospeed performance DTS, AMS snub mount, and RS4 motor mounts all as a pack make a extremely change in the car.
autospeed DTS 280
AMS mount 25
motor mounts i think is some where around 100 each
autospeed DTS 280
AMS mount 25
S4ORCE2001
[img]modules/pnCPG/Coppermine/albums/userpics/11037/rs246_thmb_s41.jpg[/img][img]modules/pnCPG/Coppermine/albums/userpics/11037/rs246_thmb_s42.jpg[/img]
Users browsing this forum: Majestic-12 [Bot] and 69 guests
