Private Messages
Private Messages
I seem to have 2 PMs stuck even though I'm only using 61% of my inbox. Any thoughts?
- Teutonic Tuner
Re: Private Messages
in your outbox? If so that means they haven't been read by the recipient doesn't it?
Sprint Blue B7 RS4 gone but not forgotten...
No. I understand how PM and bb works.
My problem is this:
Folder is 60% full (119 from 200 messages stored)
You have 2 private messages currently on hold because of full folder.
Release all on-hold messages… they will be re-sorted into the appropriate folder if enough space is made available.
My problem is this:
Isn't it a bit bleedin' obvious Bam:
The 2 stuck messages have massive porn attachments and therefore can't be released.
Maybe suggest to the sender that they either re-encode at a lower res, or cut out some of the animal scenes.
Footlong, are you listening ?
Mr. Footlong uses SFTP to send my daily porn, it must be someone else...TimsterRS4 wrote:Isn't it a bit bleedin' obvious Bam:
Shagga? It's the sort of thing he'd do (the blithering idiot).
Edit: No, make that Kiwi..... it's so obvious when you think about it.
Tim, you are so right that it's wrong.TimsterRS4 wrote:Shagga? It's the sort of thing he'd do (the blithering idiot).
Of course, a filthy Kiwi sending sheep-shagging porn to a decent Australian, I don't know how I didn't see that one.
@ Kiwi: I've found it best to encode sheep porn in 3gp format with a 10x10 pass for the spot-level brightness filter. You need to use that because there's just too much white wool in each scene, unless, of course you're trying to shift me some interracial (black sheep on farmer OR Maori man on white sheep). If that's the case, use a 5x5 multi-pass filter. Please name the files sequentially from the "Justin Bieber - My World" album.
Cheers mate.
just sent you one bam ... no porn im afraid
Laugh about on the floor or something.bam_bam wrote:Tim, you are so right that it's wrong.TimsterRS4 wrote:Shagga? It's the sort of thing he'd do (the blithering idiot).
Cheers mate.
bam_bam wrote:No. I understand how PM and bb works.
My problem is this:
I have the same bam only I have 4 held that way........and mine are not porn either!!!
950 nm torque!
Ohh running bridgestones because they are the best
You could always try texting/calling Bam instead, Panda.
Amar, Ima gunna crush your hand next time I shake it.Amar wrote:You could always try texting/calling Bam instead, Panda.
I would say that is more then fair, and I would say I am getting off lightly consdering.
- Mr Footlong
Pfft, only because you are too fecking cheap to pay for newsgroup access.bam_bam wrote:Mr. Footlong uses SFTP to send my daily porn, it must be someone else...
Current:
Gone:
Gone:
Users browsing this forum: Shoppinit and 12 guests
