Car sitting lower on one side ?? Help.
RS4_46
Post by RS4_46 » Mon Mar 26, 2012 2:15 pm
Hello
Picked up my 2007 RS4 Avant on Friday....amazing car but I've noticed it's sitting lower on one side at the rear (front is fine).
Ground to wheel arch on passenger side is 64cm, ground to arch on drivers side its 67cm (currently has a full tank of fuel).
It's only covered 27,000 and has had the DRC suspension replaced on both sides by Audi a year or two ago due to the leaky shock issue.
My car doesnt have the Sport Plus spring option and I've not noticed any knocking sounds etc.
So, is this to be expected if not any suggestions??
Many thanks
DazN
Re: Car sitting lower on one side ?? Help.
Post by DazN » Mon Mar 26, 2012 2:31 pm
Mine was exactly the same when I got it and I realised it's something to do with the way it's driven.
DRC is purely mechanical so if you corner hard to the right and then park it might sit lower one side, if you did the opposite and looked the other side might be lower.
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
DazN
Post by DazN » Mon Mar 26, 2012 2:38 pm
Forgot - FON!
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
RS4_46
Post by RS4_46 » Mon Mar 26, 2012 2:39 pm
Thanks for the reply.
So effectively when it's resting it could favor one side depending on how it was driven in the moments before parking up, but when driving it levels itself up and is balanced?
DazN
Post by DazN » Mon Mar 26, 2012 3:08 pm
RS4_46 wrote:Thanks for the reply.
That's my understanding of it, I had an Audi Master Tech explain it and it baffled me a bit but in a nutshell you're correct.
I wouldn't worry about it anyway ;-)
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
DazN
Post by DazN » Mon Mar 26, 2012 3:11 pm
I also asked the same questions when I bought my RS4, funny how much I didn't know then!!!
http://forum.rs246.com/viewtopic.php?f= ... er#p428545
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
P_G
Post by P_G » Mon Mar 26, 2012 3:16 pm
Quickest way, jack both sides up at the rear, let it hang for a while and then lower onto the floor again. It should sort out the ride height on each corner.
sar
Post by sar » Mon Mar 26, 2012 4:24 pm
i had the same, turned out the bottom 2" of the n/s/r spring had snapped off and gone walkies!.
ArthurPE
Post by ArthurPE » Mon Mar 26, 2012 6:38 pm
3 cm (over 1") seems like a lot, mine vary ~5-6 mm side to side
even after driving hard and parking it (I've measured it at least 20 times before and after my H&R install to see the difference and if they settled)
you need to take a good look at it as others suggested
broken spring
broken/disconnected sway bar link
etc.
rs4blacked
Post by rs4blacked » Mon Mar 26, 2012 6:41 pm
I had this turned out to be a broken spring best to check them I say
Currently Mondeo ST155 & Titanium X Sport
RS4 Phantom Black, Black Optics, Tech Pack, Milltek Non Res Non Valved
adsgreen
Post by adsgreen » Mon Mar 26, 2012 10:03 pm
Also when you test the car the ground needs to be perfectly level. Doesn't take much to cause a noticeable difference.
Easiest thing to do is:
-Park up
-measure
-turn car 180 degrees and remeasure in same spot
-remeasure.
Everytime I've done mine it's moved to the other side when retesting so ground not level enough.
Dave_Hedgehog
Post by Dave_Hedgehog » Tue Mar 27, 2012 9:01 am
or you could just put down the pies :biggrin3:
Dave7
Post by Dave7 » Tue Mar 27, 2012 11:03 pm
i would say 3 cms is way too much. Like Arthur says, 5-6mm seems acceptable as its a mechanical system but over an inch would point to a issue somewhere.
Arthur, do your height differences move about from side to side or are they always the same i.e. one side is always higher?
I have just had all shocks replaced under warranty and when I got it back, the fronts differ by about 6mm and the rears by about the same.
My nearside front is high and my offside rear is low - as they are connected (diagonally) it would seem that for some reason its not balancing in the middle like the other diagonal side. Audi Yeovil had it in for 2.5 weeks messing with it and have now told me that they can do no more. Its now going to a different dealer on Thursday this week to see if they can shine any light on it.
It makes no difference how its driven, it always seems to be slightly out on these corners. i was thinking that it could be a valve issue as Audi dont replace valves anymore when they replace the DRC because the new tool can measure the pressure at each corner of the car whereas the old tool (C5 RS6) wasnt able to do this so they used to replace the valves as a matter of course. Althgoh having said this, they told me that the pressure was the same at every corner so that would suggest that its not the valves... A broken spring would suggest my issue as sitting lower at the rear offside would raise the front nearside...
I'll let you know how I get on after its been in on Thursday this week.
I must say though that the car drives and feels fine...
I am thinking the following:
Rear sway bar disconnected / broken?
Broken rear spring
Oil filled top mount issue
valve issue
One thing is for sure, making cars complicated is a pain in the arse! :audibash:
56 B7 RS4 Saloon in Sprint with Black Optics, Privacy Glass, Buckets and FBSW
O
Brooner
Post by Brooner » Thu Mar 29, 2012 8:37 pm
this happened to me recently turn out to be the end of the spring was broken i would think this is the problem if the DRC looks all ok
ArthurPE
Post by ArthurPE » Fri Mar 30, 2012 3:11 am
my passenger side is always a bit higher, both front and rear, but only 3-5 mm or so
fokker wrote:.....
Users browsing this forum: Google [Bot] and 59 guests
