Vibration @ about 1400rpm
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Lewis
Post by Lewis » Thu May 20, 2004 9:10 pm
I have noticed recently, as driving with the windows open in the sunshine, that my cars has a tinny rattle / Vibration. only happens about 1400 rpm under gentle acceleration. Doesn't sound major, sounds like loose bracket or heat sheilding. Checked along by the exhaust, all seems tight there.
Any ideas, thought it might be the bracket holding the undertray, as that doesn't look to strong?
Lewis
Nogaro Blue S4 Saloon
(Very Standard For Now!)
Mik
Post by Mik » Fri May 21, 2004 9:55 am
Could be the Heatshield problem. I suggest you take it to your local Audi shop and have them check it out.
Mik
DavidR
Post by DavidR » Fri May 21, 2004 10:51 am
Agreed, sounds exactly like the heatshield. If you search here, there is a cheap fix for the problem if you car is out of warranty.
DJG
Post by DJG » Fri May 21, 2004 11:28 am
Yes I think Toasty managed to fix his rattle himself.
Dippy
Post by Dippy » Fri May 21, 2004 12:19 pm
Did he fix his teething ring too?
2001 Silver S4 Avant
Mik
Post by Mik » Fri May 21, 2004 12:26 pm
That would be a short term fix - the heatshield problem is part of a more serious turbo related issue (at least on early models). It required chaging of both manifolds and turbos.
Mik
Lewis
Post by Lewis » Sat May 22, 2004 10:54 am
Thanks,
It's got to go for a service within the couple of months so I'll get them to check it out. Any idea on price as it's out of warranty!
Also is it just loose, or is it more serious and is it likely to do any damage?
Lewis
Lewis
Post by Lewis » Sat May 22, 2004 1:23 pm
Had a look at the Topic "Exhaust Manifold" from Jun 2003.
In there there is lots of discussion about trying to get the job done on Warranty.
drbroadbent refers to Direct Warranty covering it, I take it from looking at there list of whats covered this is only under the Gold Package?
Has anyone actually had Warranty Direct pay for this job?
Lewis
Lewis
Post by Lewis » Sat May 22, 2004 5:50 pm
Have had the car up the ramps today, and if my understanding of what and where the heatsheilds are is correct, then I believe the rattle is caused by the one on the nearside.
I am assuming what we are talking about is the shield over the top of the turbo just in front of the bulkhead. There appears, looking at it from the top, (coolant resovoir removed) to be a bolt on either side to the front near the back of the block.
I put the car up the ramps and went underneath, the back of this appears to be secured with Jubilee clips. All of these seem tight.
Also viewing it from underneath you can see that the bolts go through to a bracket. the one furthest from the wing is visable and appears fine. However the one the otherside is obscured from view even with a mirror, but as this is where it appears to be loose, I can only assume that this bracket has broken.
With this in mind I can't see why it's a big issue, surely if I secure it in some other manor it will stop the vibration and as at present the cars performance seems uneffected why is it so serious?
Lewis
Users browsing this forum: No registered users and 104 guests
