Evening all, changed the rnsd to rnse last year - vast improvement! Have now picked up the Bluetooth kit and wondered if it was a DIY job or should be left to the pro's?
Guy I bought it off said the Bluetooth module would normally sit under the drivers seat but this is quite a lot of hassle (taking seat out etc). Said there is tons of room behind the glovebox and he would fit it there.
Anyone retrofitted? Is it fairly simple or does it involve removing a lot of trim. Is the wiring for the mic already there as the wire is not that long - kit is all oem and Audi branded.
CheeRS
RNSE Bluetooth retrofit c5 rs6
Re: RNSE Bluetooth retrofit c5 rs6
Hmmmm I am sure everything went behind the unit in the dash apart from tv unit which went in the boot and the microphone in the center light ..........give craigyb a pm and ask him as he fitted mine
950 nm torque!
I did mine and ended up fitting it just behind the centre console near where your left leg would be. Doing it again I'd have put it behind the glovebox. 4 screw's to take out for the glovebox and your done. there is loads of room to play with and access to the centre console for the wiring. Only took me about an hour to fully fit mine inclusing the RNS-E. The wiring for the mic should be attached to the cable that plugs into the BT unit. It should be long enough to get up to the over head light.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Users browsing this forum: No registered users and 111 guests
