oil cooler pipes split
Re: oil cooler pipes split
My oil lines are showing corrosion, Doug emailed me a picture so I am getting him to replace mine, fingers crossed the cooler is not going to need to be replaced!
Preventative step I am hoping.
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
- voyager162
- 1st Gear
takes an hours labour to carefully remove grind the nuts off the cooler inlets and split them, still an hrs labour is cheaper than a new cooler.
Aberdeen Audi wouldn't give me any good will gesture, no matter how much I complained. £1200 for me.
Chris
Chris
- voyager162
- 1st Gear
Did they wear a mask and hold you up with a flintlock pistol ?Aberdeen Audi wouldn't give me any good will gesture, no matter how much I complained. £1200 for me.
tbh if the audi tech's are unwilling to take the time to remove the nuts without damaging the cooler i would tell them to stuff it and as an independent garage to do it for you, the pipes are just shy of £300 plus an hrs labour to remove the bumper hrs labour to do the nuts and an hour to refit, so max should be £300+3hrs
£1200 is just shocking, especially when its a corrosion issue related to incorrect parts specification.
Users browsing this forum: No registered users and 207 guests
