Possible Issue - New Logs Added - Update 25/3/12
marv8
Re: Possible Issue - New Logs Added
Post by marv8 » Sat Mar 03, 2012 1:04 pm
Forgive me for asking but what range should the engine load run? Percent (par cent/by 100) would surely max out at 100 but the engine load on the second log runs to almost 180%?
Must learn more about these logs as are invaluable understanding the car
Edit - just check my last logs and got to 189%....
Ryan_Pestell
Post by Ryan_Pestell » Sat Mar 03, 2012 8:02 pm
cheers for the advice Shop, most helpful, those logs do certainly show the missfire up.
but it only did it the once, it wsa the only time during those logs it did it.
will change a coilpack round tomrrow and try another log.
interesting about the boost, as it certainly doesnt feel as strong as it used to.
Daytona RS6+ Sold :(
Now Building a 500HP Lotus Exige
Post by Shoppinit » Sat Mar 03, 2012 8:05 pm
marv8 wrote:Forgive me for asking but what range should the engine load run? Percent (par cent/by 100) would surely max out at 100 but the engine load on the second log runs to almost 180%?
I don't know what the load relates to. It certainly isn't necessarily 100% when you are standing upright on the accelerator. I've never found any use for it, so I ignore it. If anyone can shed light on what it's for, I'll be interested to know.
Post by Shoppinit » Sat Mar 03, 2012 8:07 pm
Ryan, cylinder 7 was logged in the DTCs as well, so it's obviously the worst one. I'm not sure whether the other DTC means that other cylinders are misfiring also, or whether it show up when one or more cylinders misfire.
Do you know what plugs you have in?
Ryan_Pestell
Post by Ryan_Pestell » Sat Mar 03, 2012 8:22 pm
just looked through paperwork, and on the QST invoices its just listed as plugs, so unsure, easiest way is going to be take one out when i swap the coilpack around.
looking at the actual mbar it does occationally reach over 2000.
Post by Shoppinit » Sat Mar 03, 2012 8:25 pm
Yeah, but not often, and it doesn't get there quick enough. At one point you are WOT and 2100 of boost is being asked for but only 1800 odd is being reached, and this for several seconds at high rpm, too.
Ryan_Pestell
Post by Ryan_Pestell » Sat Mar 03, 2012 8:29 pm
ahh ok. like you say will sort missfire first and then see about the lack of power.
turbos on there way out? eeekkk?
hmmmm
Ryan_Pestell
Post by Ryan_Pestell » Sat Mar 03, 2012 8:31 pm
N75 was changed last year according to previous owner, less than 5k ago.
Mr V10
Post by Mr V10 » Sun Mar 04, 2012 12:21 am
Lucky you have that sexy Inchape warranty eh?
Ryan_Pestell
Post by Ryan_Pestell » Sun Mar 25, 2012 11:53 am
Right swapped coilpack 7 with coilpack 5 and run the same test again this morning.
car is flat as a pancake, no doubt its not as quick as it used to be.
logs from about 30 mins ago.
NEW LOG-01-015-016-017.xls
(248.5 KiB) Downloaded 76 times
LOG-01-001-114-115.xls
(29 KiB) Downloaded 73 times
Ryan_Pestell
Post by Ryan_Pestell » Sun Mar 25, 2012 12:28 pm
So still missfire on 7, cleared fault codes before run and no codes came up after the run.
Spark plug?
Car feels like its 400hp, feels shockingly slow
sweegie
Re: Possible Issue - New Logs Added - Update 25/3/12
Post by sweegie » Sun Mar 25, 2012 2:34 pm
Hi Ryan,
Cant see the misfire count in your logs - you still seeing cyl 7 with the problem after the coil pack swap? As you're duty cycle on the n75 isnt maxed out, i'd say you're running into a limiter in the ecu somewhere, rather than an n75 fault or wastegate actuator problem.
I'd certainly be pulling the cyl 7 plug for a look, and probably popping a new one in or even swap with an adjacent plug. Dont rule out a clogged fuel injector also - very possible to get misfires due to a bad spray pattern so running some injector cleaner through might help too.
HTH
Recycling dinosaurs for fun
Ryan_Pestell
Post by Ryan_Pestell » Sun Mar 25, 2012 2:38 pm
Missfire starts at time log 362 secs.
Don't understand why there would be a limiter. Certainly wasn't there before
Yeah might whip te airbox off again and have a look at plug 7.
Hedgehog Dodger
Post by Hedgehog Dodger » Sun Mar 25, 2012 9:41 pm
Shoppinit wrote:Yeah, but not often, and it doesn't get there quick enough. At one point you are WOT and 2100 of boost is being asked for but only 1800 odd is being reached, and this for several seconds at high rpm, too.
Is that 1800 on both turbos or just one? If both I would say air leak from IC/Hoses/BOV's.
(sorry cant read attachments)
:biggrin3:
I love drag racing and track racing. I have had many fast cars and below is a short list of the ones most memorable.
MR2 Turbo REV2 (standard) > MR2 Turbo REV1 300HP> MR2 Turbo REV3 450HP (Nick Name Biscuit tin) > Celica GT4 ST205 WRC 300HP > R32 GTR 425HP > Honda Integra DC2 (standard) > EVO GSR 300HP > R32 GTR 450HP
Now on the hunt for an RS6
Post by Shoppinit » Mon Mar 26, 2012 8:11 am
The turbos pool on this car. There's only one charge pressure sensor.
I like the sound of the injector. Swap plug 7 with another cylinder and the injector with a different cylinder again?
If that doesn't work, might be worth looking at the fuel pressure being delivered. When's the last time the filter was changed?
Users browsing this forum: Google Adsense [Bot], philS2 and 81 guests
